Old 04-15-2010, 02:31 PM   #41
rsl
ok so I installed the TM-2025 and have learned that my converter is only putting out 13.6 volts, I can not seem to get it to go into 14.4 bulk mode. Any thoughts????
2010 Cherokee 295U 36 foot 5th Wheel.
rsl is offline   Reply With Quote
Old 04-15-2010, 04:16 PM   #42
NWJeeper's Avatar
Typically the chargers will put out max amperage at around 13.2 to 13.6 volts until your battery bank is up to 90% charge. Using the Trimetric you will notice that once at 90%, the charge amperage will drop off to around 1 amp but voltage will remain at around 13.6. The rise to 14.4 volts only happens at the very end of charging and could take 24 hours or more to appear. Some chargers work on a timer and don't put out the 14.4 volt but every 21 hours or more such as the PDI chargers. It won't happen immediately.
Ed & Wendy
www.nwjeepn.com
