Old 03-17-2010, 12:19 PM   #1
rsl
Need help with specs
The power panel in my 2010 Cherokee 295U 5er came with no manual on the power panel. I need help identifing if it is a 2 or 3 stage charger, has an inverter builtin and so on. picture is attached, I think the brand is WMF
2010 Cherokee 295U 36 foot 5th Wheel.
rsl is offline   Reply With Quote
Old 03-17-2010, 02:34 PM   #2
Head Rambler
It should be a 3-stage but your picture is a little close to get that info. Take a few more pics and maybe a little futher away and we'll be glad to help.
Gotta go campin!
Old 03-17-2010, 03:24 PM   #3
ronhanson's Avatar
It looks like a WFCO 8955 possibly. If so 3 stage, but you should be able to find the model number and make on there somewhere.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 03-17-2010, 05:44 PM   #4
rsl
that is the only thing left on it original, all of the other info is covered up by stickers that forest river put on it to identify the breakers
Old 03-17-2010, 07:01 PM   #5
Newb
I can't help you, but we were so close to buying that same model 5th wheel! It's gorgeous. In fact, some days i do wonder if i made the right call going with a TT...
CDR, U.S. Navy
Me, him, 2 kids, 1 dog
F-350 (V-10) to tow
2010 Rockwood Signature Ultralite 8317RKSS
PattiPatti is offline   Reply With Quote
Old 03-18-2010, 10:51 PM   #6
rsl
bigger picture??
Old 03-18-2010, 11:26 PM   #7
NWJeeper's Avatar
I would contact FR and ask what the conveter is. From what I can find on the net it is a WFCO converter and most likely a 3-stage but don't trust that unless you can find some documentation for it. Did FR not provide a manual for it?
Also it is very unlikely that it has an INverter built into it (converts 12VDC from your batteries to 120VAC) as most dont. This should purely be a Converter/Charger which converts 120VAC to 12VDC for your systems and charges your battery. The only way to know if it is 3 stage is if you have a way to monitor it's max output which will be in the neighborhood of 14.4 volts. Even 3 stage converters will show 13.6 volts output as this is standard.
I didn't have any luck searching for "70VF" and even WFCO's web site does not list that model so there might be something elsewhere (unfortunately under a tag?) that lists the true model number.
Ed & Wendy
www.nwjeepn.com
Old 03-20-2010, 03:10 PM   #8
rsl
I hunted around the panel and found a WCFO sticker
Old 03-27-2010, 10:05 AM   #9
rsl
OK here is what I found out, It is a WFCO Model WF-8955PEC. Does anyone no anything about this unit? 2 or 3 stage, is it a decent unit or should I replace it with something better? Does anyone know where the battery level monitor gets its level from; the furance ran for like 30 minutes out of everyhour overnight on battery power and when I checked the level this morning it was at 2/3????
Old 03-27-2010, 10:41 AM   #10
acadianbob's Avatar
Others may prove me wrong but I think your battery monitor is a simple voltage monitor. I found the stock monitor to be grossly misleading. When it reads 2/3, you are almost dead for any useful purposes. (at least with my stock monitor). So I bought a simple Voltminder and hooked it into the buss to get a more accurate read. I found that, by the time my stock monitor showed 2/3, the actual charge was getting down around 50 to 60%; which means virtually nothing left; about 12.1 to 12.2 volts. You should never take your battery down below 50%. So, when I start seeing 12.3 volts or so, on comes the generator as you've already used at least half of your available power, while your stock monitor still says 3/3. I also like the Voltminder because it tells me the rate at which my WFCO is charging when I am running the generator. (We dry camp almost exclusively). There are more sophisticated devices out there for monitoring that give you even more information but I didn't want to spend that much. Some other members have gone that route and could tell you about that.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
