Old 07-22-2011, 11:01 PM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
Need opinion ASAP!
So tonight i was headed to the bedroom and when i got to the bathroom there was water running across the floor! checked where it was coming from and thought it was the toilet, nope coming from vanity! open door and the bottom had bout 1/4 inch of water in there! it was coming out from where the line out to the toilet goes and i think going out under the cabinet towards the fridge... upon closer inspection and cleaning we cannot determine what water line it is coming from but there is leaking somewhere.. Also the wall behind the toilet seems black at the bottom and we think there might be rotting or mold happening..
Also warranty runs out this month (will be 1 year we have had this place)
floor plan
this is after mopping up with rags and so forth
so should i contact dealer? Forest River? insurance?
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-23-2011, 05:23 AM   #2
DAISY BOYKIN's Avatar
By all means forest river !
I would bypass the dealer and go direct to Forest River. They will tell you to go to dealer, that way Forest River has been alerted in advance to problem. Us pictures by email to show to FR about the problem.
Good Luck
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-23-2011, 11:36 AM   #3
The_Stuff's Avatar
well no-one open at forest river today so i called dealership. they said to clean it up (obviously) and find the source and call back monday when the techs are in etc.
so i got down there again, water is all dried up now from the fan running all night. looks like its leaking around the water pump connection to the rest of the trailer and around the filter for the pump.
now today its dried up nice but what a mess of sawdust and crap under there...
where its been leaking. it was dripping but hard to see
I tried to tighten the connections by hand but they are already tight as i could get them. so not sure if its bad fitting, put together dry (no teflon tape) or just my luck... im just worried about the wall in behind the toilet. not sure how long this has leaked and if there is any problems that will be because of this..
Old 07-23-2011, 12:02 PM   #4
Dave T's Avatar
Teflon is not needed or recommended by shurflo on any of these connections. It can damage the pump. If tight, that means only 1 of 2 things. The fitting is cracked or something is wrong with gasket or seal on the pump side of the fitting. The leak appears to be on the city water side of the pump so that would be under high pressure. I would unscrew that fitting & check seal or gasket.
Dave T is offline   Reply With Quote
Old 07-23-2011, 12:04 PM   #5
The_Stuff's Avatar
since i dont use the fresh tank i am thinking of just taking off and putting a garden hose end cap on there and be done with the pump. easy to hook back up if i need to again.
Old 07-23-2011, 12:19 PM   #6
Dave T's Avatar
That may work but I would use it only temporary. I would have it fixed right while under warranty . Me, I have to know what the problem is or I can't sleep at night.
Old 07-23-2011, 01:10 PM   #7
JoeR's Avatar
I had a problem like this on my previous camper. Try unscrewing that cap and put an O-ring inside to seal the cap on the fitting. I couldn't tighten it enough to keep it from leaking until I went down to Autozone and got an o-ring multi-pack and no more leaks.
JR
JoeR is offline   Reply With Quote
Old 07-23-2011, 01:23 PM   #8
The_Stuff's Avatar
You mean o ring or garden hose washer?
Old 07-23-2011, 01:38 PM   #9
JoeR's Avatar
I was fixing it on the fly. I got a fat o ring that just fit inside the cap and screwed it back together. If a garden hose washer fits, even better. I honestly didn't think of that one at the time I was dealing with the leak.
Cheap to try either one tho.
JR
Old 07-23-2011, 01:52 PM   #10
The_Stuff's Avatar
so thats a possible easy fix.
what about the wall behind the toilet? should i still be concerned about that?
