Old 10-26-2014, 05:03 PM   #1
Need Satellite Dish hookup help
Have a 2015 Silverback that came with a Dish receiver. I also have Dish cable at my home. Want to buy a HD Dish with tripod....I saw for sale. The satellite dish has the 3-LNB.....?? With 3 wires coming out. So my question is, how do I connect the 3 wires into only 1 connection on my 5th wheel?
Thanks....any help would be great!
fordguy is offline   Reply With Quote
Old 10-26-2014, 05:23 PM   #2
DAISY BOYKIN's Avatar
Three wires
The three wires were for three receivers. You only need one wire!
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 10-26-2014, 05:43 PM   #3
realebill's Avatar
the 3 wires are for routing 3 satellite signals. they are routed through a dpp44 switch and down to 1 lead to 1 receiver. you actually only need 1 wire from 1 LNB to a receiver. that will allow you to get the signal from 1 satellite.in my case here in the east,I pick up the signal from satellite 119.
the diagram shows 4 different output situations.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 10-27-2014, 07:13 AM   #4
cpaulsen's Avatar
I have the same dish....have always just one lead and get all 3 satellites.
cpaulsen is offline   Reply With Quote
Old 10-27-2014, 09:17 AM   #5
Talking Thanks
Thanks for all your help. Will buy the Dish satellite today and hook it up. I have read that you can't use the cable hookup located in the bay?? I guess it still goes through the booster even with the booster button off. Someone said the cable hookup is on the roof......or do you think I'm reading too much!
Old 10-27-2014, 09:52 AM   #6
Taranwanderer's Avatar
The "cable" inlet always goes through the booster, even if it's off, and the satellite signal gets "lost" because of this. You can't use the cable jacks at all, you need a dedicated satellite inlet jack on the outside of your camper running to a jack by your TV. Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-27-2014, 10:02 AM   #7
The cable hookup on your roof is for a roof-mounted satellite receiver aka a Winegard Trav'ler. You wouldn't/couldn't use that for a free standing satellite receiver.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 10-30-2014, 08:10 PM   #8
j2detroit's Avatar
when I hooked up our dish I could not get any signal through at all so I just ran a new dedicated line in for it works great
j2detroit is offline   Reply With Quote
Old 10-30-2014, 09:27 PM   #9
ironj's Avatar
The older dishes needed the switch. ..the newer ones like dish 500 can run 3 receivers straight from the sats 3 outputs...internally switching the diff sat feeds)..if you need more than 3 then ur back to the dp44....I have 3 dp44's in my attic...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 11-02-2014, 10:34 AM   #10
Jimmerinwi's Avatar
For the record, a Dish 500 can only run 2 receivers with a Dish Pro Plus LNB. It only has two outputs. A Dish 1000.2 or 1000.4 can run 3 receivers.
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 11-02-2014, 10:52 AM   #11
ironj's Avatar
touche, I haven't messed with it in a while.....I remembered 3 ports...but your right...one is an lbn in..
anyway, I was just trying to point out that the switch is not necessarily needed, unless you need more than 2 outputs...(3 in some cases)
Old 11-02-2014, 11:39 AM   #12
Jimmerinwi's Avatar
Your right, one is an LNB in. Just thought I'd point out it only had 2 outputs.
satellite
