Old 10-05-2010, 08:50 AM   #11
bsmall's Avatar
My 2010 Wildcat 28RKBS came with the 16" ST's on the ground and the spare was an LT tire. I have not crawled under the trailer to read the side wall for weight information to compare with the ST's that are on the ground....
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 10-05-2010, 12:38 PM   #12
Herk7769's Avatar
Response from Cooper Tire regarding LT vs ST
From an Airstream forum Post:
"Yes, there is a definite difference between Cooper LT and ST tires.
However, it is not a "safety" difference as long as the load rating is correct for your trailer's gross weight when towed. Both ST and LT tires can be safely used for trailers. The difference in construction is this: Cooper ST tires are basically a tire that combines passenger car tire construction techniques, with heavy duty truck tire fabric and cord materials. This results in an ST tire having a high LT type load rating with the lower air pressure requirements and soft, shock absorbing sidewalls of a passenger tire. There is also extra UV inhibitors and oils added to the rubber to help in storage. This is much easier on the suspension and other components of the trailer on bumpy roads than the stiff sidewalls and higher air pressure of the LT tires. As far as tire safety is concerned, he stated that is up to the owner and how he maintains the tires, keeping the proper air pressure in the tires, and choosing the correct load rating. He stated LT tires have an advantage because of the larger choice of tread patterns and number of sizes available to choose from to suit the conditions you are towing in, such as snow, unimproved roads, etc. He also stated that it is imperative to not allow the trailer to rest on the tires in the same spot for months at a time in the off-season. This causes the fabric cords in the tire to take on a flat "set" which can then cause some of them to actually break apart when you next take the trailer out on the highway. This can cause complete tire failure. He stated the best thing to do is to store the trailer on jacks with the tires in the air, or removed completely. This last information was of concern to me since I only have "stabilizing" jacks and cannot lift the trailer enough to take the load off the tires without serious effort. At any rate, that is what Cooper Tires has to say on this subject."
Don't shoot the messenger
HAM CALLSIGN - KC3FFW
Old 10-08-2010, 07:02 PM   #13
Maxxis makes 15" ST tires in C, D and E load ranges. They are available from Discount Tire (if not listed you can ask them to order them for you). They are made in Thailand and reports have been very good. Just make sure your rims can take the extra air pressure of the higher rated tires. The max. air pressure should be stamped on the inside of the rim.
2004 Flagstaff 8528RLSS - 2005 Dodge 2500 QC LB Hemi
tgif: let's RV - HobbyTalk
HobbyTalk is offline   Reply With Quote
Old 10-08-2010, 07:54 PM   #14
Dave_Monica's Avatar
Out of curosity, what are the current tire load rating and what are your camper's axle ratings. I'm assuming that you're looking to increase the safety margin...how much safety margin to you have now with 'D' rated ST tires.
Aslo, I wouldn't discount the use of LT tires...switching to them seems to be the trend lately.
Dave
Old 10-09-2010, 11:01 AM   #15
Currently have 4 225/75/15 Titan ST load rating D. Not sure of the axle ratings. Would that be marked on the axle somewhere? The plate on the side says GVWR 11575 and GAWR 5250 lbs.
1997 FR Sierra 30RKS
2004 GMC Sierra 3500 Dually CCLB
DageonYar is offline   Reply With Quote
Old 10-09-2010, 12:12 PM   #16
Originally Posted by herk7769 View Post
I would be very hesitant with this mod.
WHY?
Changing over to 16 inch tire and wheel packages is very common and relatively easy to do. All one needs do is contact someone like Trailer Tire and wheel company and ask the question. Be prepared with your original size and they can fit you with the correct package for a simple bolt on installation.
I guess if you want to be stuck with a nearly extinct tire size and limited to only a few choices most made in China, then stick with what you have.
Personally 16 inch LT tires can be found in almost any town in N America that will do the job in a pinch. Same cannot be said for 15 inch St tires.
Old 10-09-2010, 12:17 PM   #17
UHHH where did you get this bit of misinformation from?
ST tires are designed as a trailer only tire. Have a speed rating of 65MPH and are generally bias ply tires. Which by the way became obsolete about 30 years ago for all except trailers. They claim to be built with a stiffer side wall to accommodate the turning forces placed on them. Baloney! Radial ply tires are far superior in every respect and with the proper match will have the same or higher load ratings at a lower cost. Remember your business class on the law of supply and demand?
Old 10-09-2010, 12:20 PM   #18
Yes, the axle ratings are marked on a metal tag that is affixed to each axle. Crawl under and look. You will also find the same information on a metal tag that is on the left front corner of your trailer. This tag will give you axle ratings, tire ratings and the vehicles GVWR plus the serial number.
Old 10-11-2010, 06:46 AM   #19
My guess is he is going to have 5K lb axles. So the load rating of each tire will need to be 2500 lbs or more. Maxxis 225/75R15 D rated (8 ply) tires are rated 2540 lbs. That tire has a dia. of 28.3"
The smallest Michelin XPS Rib (LT tire) is a 215/85R16 with a rating of 2680 lbs each but the dia. is 30.4". The OP needs to make sure that they would have clearance for the larger sized tire.
Also to consider is that the XPS Rib will cost about twice (plus the cost of new rims) as much as the Maxxis. The really funny thing is as I was looking up prices at Discount Tire is that they carry (or can get) the Maxxis tire but the Michelin XPS Rib is not available in our area.
Old 10-16-2010, 03:24 PM   #20
Infractee
Originally Posted by donn View Post
WHY?
While I do agree that 16" tires are the way to go, I think your assertion that 15" tires are nearly extinct and hard to find is a bit overly dramatic and a lot of hot air... you almost sound like you work for some political action committee to promote the use of 16" tires thru some sort of lobbying effort....
If you go to any wally world or Sams club, (in N. America and well beyond) you will find Goodyear Marathons in 14", 15" and 16" If you go to any Discount Tire in N. America they also sell the Marathons in all sizes, as does NTB or Tire Kingdom depending on where you are. Both Firestone and Goodyear service centers carry their own brand of trailer tires in 15" and others as well.
RhoZeta is offline   Reply With Quote
