Old 09-20-2012, 04:42 PM   #1
hkreck's Avatar
New fan connection
I'm installing two Fan Tastic fans in my solera the wiring is in the housing but it just comes out and loops around going back into the hole. To hook up the fan do I just cut the wire anduse an end or does an end pull out to use? I hope the pictures come out to show.
ID:	19727   Click image for larger version
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-21-2012, 06:54 AM   #2
ryand's Avatar
Hi- I would test for voltage to make sure it's not 110....obviously you could test Un plugged and you get 12v you are good to cut the wire and finish the install.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 09-21-2012, 10:10 AM   #3
Tug on the wires gently and see if an end comes out.If so then check voltage,if 12v then hook to fans.If the wire dosen't come out ,then cut the wire,test for 12v ,if ok then join the fans to the other wires.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 09-22-2012, 11:28 AM   #4
Just remember please to disconnect battery and shore power before cuttinh any wire.
You don't want to hurt yourself or the like.
Flying dutchman is offline   Reply With Quote
fan
