Old 06-28-2016, 06:58 PM   #11
a/c
thanks for input. I have it on the right settings, cool, fan etc. I don't think I hear the condenser kicking in
Drrayrn is offline   Reply With Quote
Old 06-28-2016, 11:00 PM   #12
[QUOTE=brack31;1242483]Do you have the Mode set to Cool or is it on Fan? It needs to be set on Cool for the A/C to turn on. With the fan set to high, once the temperature set point is reached, the A/C compressor turns off but the fan stays on to keep air moving. (If that makes sense, and in case you didn't already know)
Hey Glen, its set to cool - I have cold air coming into the coach. its just not enough.
I'll take picture tomorrow - maybe that will help...
Thanks For the help!
Mako284 is offline   Reply With Quote
Old 06-29-2016, 06:17 AM   #13
TURBS's Avatar
[QUOTE=Mako284;1243015]
What is the intake and exhaust temps?
Sent from my SCH-R530U using Tapatalk
TURBS is online now   Reply With Quote
Old 06-29-2016, 08:48 AM   #14
TURBS's Avatar
I didnt think my a/c was cooling very well, however its doing just fine.
23 difference between return and exhaust.
Ext temp 81
Int temp 76
Ret temp 67
Exh temp 44
Old 06-30-2016, 05:31 PM   #15
Have 2017 Columbus 377MB, we are having same issue, in sun and 93 outside its 84 in living room and 88 in bedroom, both units running none stop all day, start out at 65 inside, by 3:30 in afternoon it's 84-88 inside.
2017 Columbus 377MB pulled by 2016 GMC Denali 3/4 ton
HVACMASTER is offline   Reply With Quote
Old 06-30-2016, 05:32 PM   #16
Ours is ducted so no access from inside
Old 06-30-2016, 11:34 PM   #17
I have another thread about this, so obviously have the same issue with my 2017 RBOK. it will keep it around 15 below outside temp but ac' runs nonstop. I also have the upgraded insulation and thermal Windows which I'm calling bs on at this point. I added 2" pic to the return ducts to hold them open but don't think it helped. The exhaust temp is as low as 55 in the heat of the day so it's blowing cold. Just not enough air and too much heat coming in. It doesn't help that I have 2 huge shower skylights plus 4 exhaust fans and the door Windows. All of the skylights are now covered with insulation and still doesn't keep up as I would expect. The only the I haven't done is pulled the roof units to check the wiring holes..
I have really struggled to find the right thermostat settings. Lately have been setting the back ac to 65 so it runs all day otherwise it would shut off while the rest of unit was hot. I also taped up the vents in the bedroom and master bath to force more air to the rest of unit. Again, all of this didn't solve the problem but I'm guessing it helped a bit.
Jay
TV:2012 Tahoe
TT: 2012 Grey Wolf 25MB
Other Ride: 2006 Harley Ultra Classic
Jayfro04 is offline   Reply With Quote
Old 07-04-2016, 09:24 PM   #18
TandSH's Avatar
Originally Posted by TURBS View Post
Looking up through intake side.
What am I looking at here and is it correct or incorrect? Thanx for your input.
2017.5 Cedar Creek 34RL2
2016 Flagstaff 8528IKWS Diamond Pkg (For Sale)
2016 F-250 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 07-04-2016, 09:42 PM   #19
TURBS's Avatar
Looking at the return and exhaust divider, you can see where it has come loose from the two sided white tape.
Therefore allowing intake and return air to mix.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 07-05-2016, 09:31 AM   #20
Head Rambler
I just talked to my BIL this weekend and his A/C had the same problem shown in Turbs' pic. Apparently it's a lot more common a problem than I thought.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
