Old 07-30-2011, 08:36 AM   #1
new tires
hi I have .a ceder creek 34 rlsa and need tires ,I am looking at Michelin xps but are pricey and good for only 300034 lb what do you think?
jutojohn is offline   Reply With Quote
Old 07-30-2011, 08:47 AM   #2
Wanna Be Camper
SaskCampers's Avatar
300034 wow thats like 1.2 million lb and the what the hitch can carry, sure your truck is up to the task? Sorry I couldn't resist. I am assuming you meant 3034lbs. So x4 would be 12136lbs + the pin weight so where ever that leaves you as I am not familiar with your unit.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-30-2011, 08:59 AM   #3
hay moose jaw thanks for nothing
Old 07-30-2011, 09:09 AM   #4
Wanna Be Camper
Not sure why the snide remark but if you took my info and went to FR's site like I did and added the over 2k dry pin weingh you would see you are ok. Also you never mentioned what your current tires are rated for? And if they are rated for more why would you look at a lower rated tire to start with?
John & Deb
