Old 04-09-2014, 08:58 PM   #1
Kennykling
kennykling's Avatar
Newbie popup owner
I just bought a rockwood popup camper. I was wondering about a good website for parts. I think I need a control board for the furnace and a faucet.
kennykling is offline   Reply With Quote
Old 04-11-2014, 09:15 PM   #2
RV Wholesalers and PPL motorhomes both have good parts departments. Of course amazon can be your friend as well.
Before you buy parts, tell us the year and model of the pop-up. Also, what is going on with the furnace that makes you think you need a control board? What kind of faucet do you have in the camper (hand pump, or does it look like a residential faucet)?
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 04-11-2014, 10:11 PM   #3
Oklahoma Proud
MillerTime's Avatar
Ebay.
I get parts for everything off of there. Just need to know make, model (of appliances), and other numbers sometimes.
Plus you can see feedback of seller!
MillerTime- Future Sabre Handler!!
Old 04-12-2014, 09:37 AM   #4
Kennykling
kennykling's Avatar
I have a rockwood model 2040. What happens with the furnace is, it lights fine for a few seconds and the cuts off. I have gone thru and cleaned and tested everything and the only thing I can think of is the control board. I bought the camper for $100.00 from a real good friend. Long story how he acquired it. Also I plugged it in and am getting power to the converter inside ( it has a low hum noise so I assume power is getting to it) but checked power to the receptacles with no power. I am assuming the converter is bad. I've heard they are about $200. There is currently no faucet. I'm not sure what to buy for it. Any and all help would be greatly appreciated.Click image for larger version
Name:	ImageUploadedByForest River Forums1397313415.081622.jpg
Old 04-12-2014, 09:47 AM   #5
Oklahoma Proud
MillerTime's Avatar
U might look under the counter at the line connections. A cheap faucet from walmart might work, or at least easily returnable if not.
Don't know much about furnaces, someone else will have to chime in. Only thought I have is maybe a restriction in the gas flow, where it is starved out after a few seconds of burning.? Thats all I got
Old 04-12-2014, 09:49 AM   #6
Kennykling
kennykling's Avatar
I have checked all the wiring under there and it seems right. I might have to take it somewhere because electrical stuff is not my thing. Thank you so much for the response
Old 04-12-2014, 02:35 PM   #7
bikendan's Avatar
usually, popups that small, have a hand pump faucet.
does yours have a electric water pump?
have you tested the wires to the battery?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-12-2014, 03:08 PM   #8
B D HOWie's Avatar
Is one of the receptacles GFI? Could be that it needs reset (maybe replaced) and all the receptacles will work.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is online now   Reply With Quote
Old 04-12-2014, 04:04 PM   #9
Kennykling
kennykling's Avatar
I checked for a gfi receptacle and didn't find any. I wish it would have been that easy.
Old 04-12-2014, 04:44 PM   #10
Our popup had a hand pump faucet. You actually pumped it and it would suck water out of the FW tank. If you had city water, you pushed the other way and it would let the city water through.
2011 Traverse LT, 3.6L, FWD
newbie, pop up
