Old 08-15-2011, 06:50 AM   #21
All I know is the FACT that my TPMs told me the nitrogen tires rose more in pressure than the air-filled. They are accurate, so I have no question about that FACT.
Maybe the racing "experts" can explain that?
Old 08-15-2011, 07:28 AM   #22
MtnGuy's Avatar
Originally Posted by windrider View Post
Note to moderator, start a poll, if you have had a tire blowout in the last 12 months, were your tires filled with nitrogen? Add in date of blowout, date last pressure check, and did you check the tire tread and sidewalls, and speed at which traveling. Let's quit with opinions, and get some data, then we can make a decision with data to back it up.
windrider, any member can start a poll. I think in the case of this 1, with the probability that more people run air than nitrogen, it would indicate more blowouts with air.
Old 08-15-2011, 11:23 AM   #23
Anacortesians
Nitrogen will not support spontaneous combustion/explosion in your tires. That's its only benefit. Large airplanes use nitrogen for that reason. There were several airline and military airplane accidents back in the early 1960s caused by in-flight tire explosions after the landing gear was retracted, usually caused by an overheated brake that had dragged during taxi and takeoff. After Boeing did some research, they recommended a switch to nitrogen.
If your RV can do 140 mph for two miles or so with a dragging brake. maybe nitrogen would be a good idea. Otherwise, it's a waste of money.
Frank and Eileen
No longer RVers or FR owners
Old 08-15-2011, 06:39 PM   #24
Nigels's Avatar
140 MPH with a dragging brake, no problem for my Cummins......
That should start something
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
Nigels is offline   Reply With Quote
