Forest River Forums
Sunline User Photos
Old 07-09-2010, 10:11 AM   #1
No Battery Power ?
Hi. We are new to this forum but not new to camping. Our current 5th wheel we have owned for 3 years now. It is a 2002 Wildwood 25' bunkhouse. We do a lot of dry camping and rely solely on battery power. This last weekend when we took it out, we had absolutely no power from the battery (brand new). But everything worked fine when it was plugged in to house power or to the pickup. Any ideas as to where to start looking for the problem? Would hate to take it in for repair if it is a simple fix. Thanks for helping.
cordox4 is offline   Reply With Quote
Old 07-09-2010, 10:50 AM   #2
Lou Amadio
herk7769's Avatar
If it worked before and not now, check all connections inside and outside for corrosion at fuse connections. The auto restetting ones too.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 07-09-2010, 11:32 AM   #3
Thanks for the reply. Is there a fuse just for battery power? Because everything works when plugged in. We've never had this problem before so not sure where to look.
Old 07-09-2010, 11:49 AM   #4
Lou Amadio
herk7769's Avatar
The shore power converter provides 12vdc directly to the camper through the fuse panel.
The battery has an auto-resetting fuse, looks like a Lego block, with two posts on it. It could have a red plastic or rubber cover on it.
If those connections become high resistance due to corrosion, you will lose the connection to the battery.
There may be another similar fuse under the tounge or under the pin box to protect the tow vehicle from shorts. If so you must check there too.
Old 07-09-2010, 03:30 PM   #5
Moderators' Assistant
bikendan's Avatar
could you have accidently hooked up the new battery backwards?
this would have affected the resettable fuse.
Old 07-09-2010, 03:51 PM   #6
Lou Amadio
herk7769's Avatar
This is a good point because the converter has 2 40 amp orange fuses that prevent damage to the converter if the battery is connected in reverse even for a second.
Nothing off the converter 12dc will work until the fault and fuses are replaced.
Old 07-09-2010, 04:21 PM   #7
We'll have to check out that re-setting fuse this weekend. I have a feeling that is the culprit. Until this forum, we didn't even know it existed! Thanks for the advise.
Old 07-09-2010, 05:20 PM   #8
backin15's Avatar
I had the same problem with my new camper, discovered they never hooked up the negative wire to the battery!
2010 Flagstaff 25 DS
2004 Dodge 2500 Hemi
backin15 is offline   Reply With Quote
Old 07-09-2010, 07:10 PM   #9
Lou Amadio
herk7769's Avatar
Exclamation
Get out!
Old 07-09-2010, 08:04 PM   #10
That is a very good reason you go over every inch of a new trailer when you get it home before you go anywhere. No matter how meticulous a dealer may be, he may still miss something. The fastest way to discover a problem is to camp at home in the driveway when you first get a new camper.
Hokiehall is offline   Reply With Quote
battery, electrical, power
» Online Users: 673
147 members and 526 guests
11XLITE28BH, 64c10, alpinemike, artnlisa, BeagleIL, Bigmatt, bikendan, blaisrv, BlakeB, bo criswell, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Cascade Bob, cdbus, chof16, ChrisZazzara, Cowracer, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, dapersico, davidjb, depo, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Flashg_123, Foneguy, forthefunofit, fpdeod, Gary Bridges, gator14, gmw65, grhodes50, Hamblen, HemiCab, Hilgy, hotrodj125, Itsthetwoofus, Janet H, jar3316, jjm901, jkinger, jobren4, jrb988, Juan.Cortes, kegoneill, ken0042, Kevin-and-Julie, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, Loopyhamil, LuckyMcBRIDE, mbfree66, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, Mrgary, nailit, NINA, Nursx2, PAMROBERTNC, papap, pgordemer, phone man, Piston, Playtime III, pmsherman, popbreed, Poppy Bill, Ptmaazx6, punkaccountant, pwadini, RattVader, redfox217, Retired63, rgmiller32, rick51, RJHuser, rob2112, Rogue69, rotorhead1250, SabreSam, Sahgie, Sailfish Bret, scroses40, SDENN4281, shane1234, shavard, shrimper, silly2635, SimchaSabre, skullskidr, snjparham, Snowsail, T.Kott, TacBear, tbritt, Tee, Test Account, texashatter, Timex, Titleguy, tmmar, trailraider, travyp, Triguy, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, Warrior, washdweller, wayne anthony, whj77372, wnytaxman, y01lxb, Zadnichek
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
