Forest River Forums
Sunline User Photos
Old 09-04-2011, 10:51 PM   #1
Unhappy No lights from Battery power
I have a 2010 Grey Wolf 29 BHKS. I have had no problems all summer. Today we came home and parked it beside our house to find none of the inside power works while on battery. All works fine on Shore power. Also, my slide works on battery. Nothing else does. Is there maybe a problem with the converter? Where do I find it. Is there a reset button. I checked all of the breakers and fuses found in the panel in the bunkhouse and no issues here.
jdauter is offline   Reply With Quote
Old 09-04-2011, 11:05 PM   #2
grhodes50's Avatar
Check outside the tt for a fuse or reset coming off of the battery.
Mine has auto resets, so if one goes out I have to replace it.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
grhodes50 is online now   Reply With Quote
Old 09-05-2011, 07:01 AM   #3
volunteer moderator
Go to your battery and follow the plus wire as it travels back down the hitch and
frame rail. You'll most likely find a fuse or circuit breaker underneath
the trailer near the front. Apparently the slide is connected in front
of this circuit breaker/fuse so it's still working.
This is fairly common.
Good Luck!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
KyDan is online now   Reply With Quote
Old 09-05-2011, 07:22 AM   #4
I had same problem a few weeks ago. Found a blown fuse in power line leading from battery. Replased it and all is well
jim44646 is offline   Reply With Quote
Old 09-05-2011, 01:12 PM   #5
rohlingerrv's Avatar
Hey the same thing happen to me this weekend! I checked all the fuses from the battery, 3 of them all checked good,, now what??
rohlingerrv is offline   Reply With Quote
Old 09-05-2011, 07:02 PM   #6
jdauter, please post follow up if you solve the problem,
Old 09-05-2011, 07:39 PM   #7
Lou Amadio
herk7769's Avatar
From your photo I assume you have a 5th wheel.
You problem is most likely the same as mine was. Under your pin box is a red rubber covered current limiter. Remove the corroded terminals and treat them with a nice sanding with wet and dry sandpaper. reconnect the wires. Problem should go away.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 09-05-2011, 09:31 PM   #8
Location: Jacksonville Florida - Home of the Jaguars !!!!
IF you have a travel trailer, there is a junction block under the front frame area where the battery power wires go to from the battery. This is actually a resettable switch and gets corroded pretty easily. SOME have a small reset button that can be pushed, and some are auto-resetting. Check that little junction block, I'll bet that is the problem! Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
Old 09-06-2011, 03:19 PM   #9
Yup that was it. Reset button under the belly near the A frame.
Old 09-06-2011, 03:30 PM   #10
ok I found the limiter, with 2 red wires going to it, one side is hot and the other is not,,does this mean the limiter is bad? My camper is only a year old, not corroded
battery, bunkhouse, converter, grey wolf, power
» Online Users: 662
144 members and 518 guests
11XLITE28BH, 64c10, alphadog99, alpinemike, artnlisa, BeagleIL, Bigmatt, bikendan, blaisrv, BlakeB, bo criswell, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Cascade Bob, cdbus, chof16, ChrisZazzara, Cowracer, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, dapersico, davidjb, depo, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Flashg_123, Foneguy, forthefunofit, fpdeod, Gary Bridges, gator14, gmw65, grhodes50, Hamblen, HemiCab, Hilgy, hotrodj125, Itsthetwoofus, Janet H, jar3316, jjm901, jkinger, jmswms, jobren4, jrb988, Juan.Cortes, ken0042, Kevin-and-Julie, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, Loopyhamil, LuckyMcBRIDE, mbfree66, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, mike54, Mrgary, NINA, Nursx2, PAMROBERTNC, papap, pgordemer, phone man, Piston, Playtime III, pmsherman, popbreed, Poppy Bill, Ptmaazx6, punkaccountant, pwadini, RattVader, redfox217, Retired63, rgmiller32, rick51, RJHuser, rob2112, rotorhead1250, SabreSam, Sahgie, Sailfish Bret, scroses40, SDENN4281, shane1234, shavard, shrimper, silly2635, SimchaSabre, skullskidr, snjparham, Snowsail, T.Kott, TacBear, Tee, Test Account, texashatter, Timex, Titleguy, tmmar, trailraider, travyp, Triguy, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, washdweller, wayne anthony, whj77372, wnytaxman, y01lxb
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
