11-25-2011, 09:42 AM
No power
 OK, I have no power in my Wildwood. Just brought it back from the shop to have a fan replaced in the bathroom (another crazy story) and I have trailer outside lights but NOTHING works inside. I have checked breaker box, fuses, etc. even wiring looks ok to my uneducated eye. Called the shop and they insist it was nothing they did but now want us to tow it back which is quite a drive.  The main problem is they left the vent cover open in the bathroom and we didn't notice because it was almost dark when we picked it up. We cannot get to the bathroom with the slide in and have no power to slide it out, had to put plastic over roof and bungee it for now. Any ideas?? HELP
11-25-2011, 10:55 AM
I would check any GFC outlets and reset them. Also, check to see if the battery cutoff switch has been turned off.
2008 Berkshire 390bh DP
11-25-2011, 12:20 PM
Moderator
The slide is going to run on 12 volts, so GFI outlet doesn't matter at the moment. Check battery voltage, and make sure it is hooked up, and/or cut off switch if you have one. Back the tow vehicle close enough to plug in the towing cord, (7 pin round connecter), leave the tow vehicle running, and check your slide operation. Also if you can get to the monitor panel, what does it say about tank levels, battery voltage, or does it even work? One last place, there are some breakers between the battery and the camper, trace the red wire from battery down the tongue, and look for a small box with 2 studs and nuts with the battery cable bolted to one stud. This will be the breaker, and it might have a very small "reset" button, usually on one end. There might be two breakers, one for trailer power and one for slide power. Check them both, and good luck.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
11-25-2011, 01:35 PM
Moderators' Assistant
you don't have vent covers on the vents? that should be one of the first mods you should do. well worth the money, since you can leave the vents open even if it's raining.
do you have the battery hooked up or are you simply just plugged into shore power?
if you just have battery power, there's a resettable breaker/fuse along the tongue frame, from the battery.
many times when the battery gets reinstalled, the wires get crossed and this breaker is set off, shutting down power to the trailer.
there are tons of threads on this with pics of the breaker/fuse.
Dan and Shawn and Zoe the Wonder Dog
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
12-05-2011, 10:58 AM
Thank you checked for a cutoff switch couldn't find.
12-05-2011, 11:06 AM
Well, after reading up on the whole 12 volt converter thing I realized that the problem could be the battery (after much arguing with significant other) and just hooked up a charger since there was NO READING on the wall monitor panel. Guess what, after a few hours power back! Apparently it didn't charge back up on the way back from shop. Looks like they left a light on but still thinking I need a new battery. Just didn't think a bad battery could cause so much headache. Thanks!!
12-05-2011, 11:08 AM
Nope no covers didn't know there was such a thing, will get some asap. Thank You.
12-05-2011, 01:11 PM
Never rely on your trailer's battery being recharged by simply towing it.
Most tow vehicles will only trickle charge at the most.
For a low battery, it would take hours of driving for your tow vehicle to recharge the trailer's battery.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 662 |
| 145 members and 517 guests |
| 11XLITE28BH, 64c10, alphadog99, alpinemike, artnlisa, BeagleIL, Bigmatt, bikendan, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Cascade Bob, cdbus, chof16, ChrisZazzara, Cowracer, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, dapersico, davidjb, depo, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Flashg_123, Foneguy, forthefunofit, fpdeod, Gary Bridges, gator14, gmw65, grhodes50, Hamblen, HemiCab, Hilgy, hotrodj125, Itsthetwoofus, Janet H, jar3316, jjm901, jkinger, jmswms, jobren4, jrb988, Juan.Cortes, ken0042, Kevin-and-Julie, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, Loopyhamil, LuckyMcBRIDE, mbfree66, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, mike54, Mrgary, NINA, Nursx2, PAMROBERTNC, papap, pgordemer, phone man, Piston, Playtime III, pmsherman, popbreed, Poppy Bill, Ptmaazx6, punkaccountant, pwadini, RattVader, rbrandon, redfox217, Retired63, rgmiller32, rick51, RJHuser, rob2112, rotorhead1250, SabreSam, Sahgie, Sailfish Bret, scroses40, SDENN4281, shane1234, shavard, shrimper, silly2635, SimchaSabre, skullskidr, snjparham, Snowsail, T.Kott, TacBear, Tee, Test Account, texashatter, Timex, Titleguy, tmmar, trailraider, travyp, Triguy, True Believer, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, washdweller, wayne anthony, whj77372, wnytaxman, y01lxb |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
