Originally Posted by Johny
May have figured it out. I have the cold water valve toward heater and the hot 1/2 way between heater and bypass line. Seems to be the only way to get water. But I don’t understand why valve would be 1/2 way.
Have you run the water long enough to fill the water heater? It takes a long time to get 6 gallons in there. Put the valve in the proper position first, so it points at the water heater, not the bypass line.
And make sure the anode rod/plug is installed. (You may have a huge puddle outside the trailer.
Write back and tell us what you found.
Larry
