Old 07-05-2016, 07:48 PM   #11
tahoe1840's Avatar
I had an issue with one of my Fantastic Vents that was in Warranty, called my dealer and they were no help at all. I find going to a dealers with warranty issues are worthless so I went online and got the support folks from
Fantastic Vent to help, amazing experience, not only were they helpful but shot out my needed part that day and I got it within 4 days. Might I suggest if you are going to be somewhere for an extended time, say a week, give them a call ahead and see if they can expedite to you whatever you need to where you will be.
tahoe1840 is offline   Reply With Quote
Old 07-05-2016, 07:53 PM   #12
Flybob's Avatar
X2
The warranty for the fan ( and most other appliances) is from the appliance manufacturer and not FR. Call them. Odds are they will send you the part and instructions if you want to do it yourself or provide you with an authorized dealer close to you that can do it for you.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-05-2016, 08:06 PM   #13
I had the squeaking issue from our previous trailer. Looked like the motor bracket was supposed to be mounted on rubber feet or a spacer yet it was screwed right to the housing causing the fan blade to be too close to the screen. I took the pop out screen off then the blade off the motor so I could remove the motor bracket screws and placed four stainless small nuts as spacers to raise the fan up a bit. I'd like to see the parts list on the fan assembly as I suspect someone left a few out on the install.
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd
2014 Jeep SRT...did not trade
Simplewon is offline   Reply With Quote
Old 07-06-2016, 07:30 AM   #14
Wolverine 1945's Avatar
A little off subject but,,, WD40 is not the magical spray many think it is !!!
WD stands for Water Displacing !!!
Wolverine 1945 is online now   Reply With Quote
Old 07-06-2016, 08:35 AM   #15
NMWildcat's Avatar
Sacrilege.... get the torches😂
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-06-2016, 09:03 AM   #16
It has always been thus...but does that exempt it from being a lubricant?
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 07-06-2016, 12:45 PM   #17
ben31's Avatar
In many cases, WD-40 actually rinses off the lubricant. Then, when it evaporates, it leaves nothing behind. It is excellent, for what it was meant to do. At other things, it can make matters worse.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 07-06-2016, 01:00 PM   #18
ilmor's Avatar
Damn, all that lubrication I've done with WD-40 over the past 40 years...wasn't!
By the way, oil displaces water too...
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-06-2016, 01:03 PM   #19
Hmmm. "Excellent for what it was meant to do." What's it meant to do?
Their website says "drives out moisture, protects, frees sticky mechanisms, removes, lubricates."
WD-40 EZ-REACHâ„¢ 14.4 OZ
Not saying I necessarily agree with all of these, but the company clearly thinks it lubricates.
2011 Traverse LT, 3.6L, FWD
Old 07-06-2016, 08:40 PM   #20
Water Displacement. Intended to be sprayed on the inside and outside of a wet distributor cap of a stalled military vehicle so it can be restarted after the distributor takes a bath in a creek, pond or puddle. Made for the military.
Oil a squeaking door hinge in your house with it and see if it don't need it again within a couple of months. Not a good lube.
2001 2500hd
fan
