Old 07-04-2016, 01:18 PM   #1
MCTroy
Not so fantastic fan
I did a quick search but didn't find any info on servicing the fantastic fans. We have the basic model in our bath. It is a 2015 so just a year old and still under the extended warranty. It is getting noisy. When running on either speed it squeaks. I tried a good shot of WD40 And it didn't help. Any suggestions on how to quiet it?
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
Old 07-04-2016, 01:28 PM   #2
WD-40 isn't actually a lubricant so try some some light machine oil.
Better to contact the FF people as they're support is fantastic (pun intended). I once had a problem with the plastic surround melting while my A-frame, years out of warranty, was stored in the Phoenix summer heat. I contacted them about buying replacement parts. They asked what year trailer. When told, they said that was the year they tried another plastic formulation that didn't work out. They sent me all the parts I needed to repair the fan free of charge. Now, THAT'S customer service.
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
azjerry is offline   Reply With Quote
Old 07-04-2016, 01:29 PM   #3
Witch Doctor's Avatar
You say it "squeaks" well I think it's a sealed motor so WD40 will not help. Is it loose in the housing the 14x14 opening and the blade is making it move, is it reversible? will it also do the same thing? might need a new motor then.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-04-2016, 04:20 PM   #4
MCTroy
Not reversible. I will take the screen off and see if anything is loose. I don't feel anything but can't get to the motor with the screen on.
The light weight oil might help too.
Thanks!
2011 Ram 5.7 hemi
Ohio River Rat
Old 07-05-2016, 12:14 PM   #5
rsdata's Avatar
search for youtube videos on cleaning and taking apart fantastic fans to take everything apart... motor should not squeak... the fan might be loose in the housing and it rubs slightly somewhere
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 07-05-2016, 04:46 PM   #6
Warranty
I thought Fantastic Fans had a lifetime warranty. I would call the factory and check.
okiegals is offline   Reply With Quote
Old 07-05-2016, 06:13 PM   #7
Swift2
Swift 2's Avatar
Are covers on the 2fantastic fans open so slow we wonder if they are even opening. Other fans we have watched are much faster. Other fans we have watched are much faster
Swift 2 is offline   Reply With Quote
Old 07-05-2016, 06:54 PM   #8
I have a quick question since e you say it is a 2015 why are you trying to fix it here? just contact the fan company or better yet FR or the warranty company I am sure any of them will be happy to help you fix the fan. since you say it squeaked and it is a sealed motor it most likely has a bad bushing, so just have it replaced and then you and your family can get back to enjoying your coach for the summer?
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 07-05-2016, 07:01 PM   #9
MCTroy
We are trying to fix it until we get back to our dealer in September. Thanks for ask the advice, I will try opening the screen to see if anything is loose. Thanks for all the tips.
2011 Ram 5.7 hemi
Ohio River Rat
Old 07-05-2016, 07:03 PM   #10
ilmor's Avatar
If you mess with it you may void the warranty.
Here is the warranty info:
http://www.fantasticvent.com/assets/...y_overview.pdf
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
fan
