Old 05-22-2012, 07:44 PM   #1
Nothing Works When Not Plugged In
I just got a used 2008 Cherokee and this is my first ever trailer so I am a rookie at this.
The battery is fully charged but nothing will work in the trailer unless plugged in. Slides won't work, jack won't work, no lights nothing.
I realize this is probably an easy solution, but I can't find the answer even on google.
Helping a rookie would be appreciated!
theweave is offline   Reply With Quote
Old 05-22-2012, 07:50 PM   #2
1. is battery connected to the trailer wiring
2. is battery charged
3. is there a battery disconnect switch
Old 05-22-2012, 07:54 PM   #3
jtstromsburg's Avatar
If those the options aren't the fix, check and see if you have a in-line fuse near the battery?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-22-2012, 07:55 PM   #4
1. Sure looks like it
2. Yes the meter in trailer shows voltage
3. That I am not sure of (first trailer!)
Old 05-22-2012, 08:35 PM   #5
Herk7769's Avatar
When you say it shows voltage which light or lights are on on the display?
HAM CALLSIGN - KC3FFW
Old 05-22-2012, 10:57 PM   #6
bikendan's Avatar
how do you know the battery is fully charged?
if you're depending on the idiot lights that are on the monitor, don't rely on it.
do a hydrometer test on the batter or take it into an auto parts store for testing.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-23-2012, 12:26 AM   #7
Terier's Avatar
"Idiot lights" is a term not often used by the younger generation...guess you are older too.
I have to say I was a little surprised to learn that the battery light on the display didn't have much to do with the level of the battery charge. I forgot to ask the service tech if that light serve a purpose even in theory?
Old 05-23-2012, 12:34 AM   #8
PrairieBoy's Avatar
I would unplug the power to the trailer then do your battery test at the monitor again and see what it reads.
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
2012 Dodge Ram 1500 4X4 CC Outdoorsman
PrairieBoy is offline   Reply With Quote
Old 05-23-2012, 04:50 AM   #9
cardinal4fun's Avatar
I would guess its either battery disconnect switch or in line fuse. The battery disconnect will be located somewhere in one of your outside storage areas. Once you see it you will know what it is as it will say battery disconnect. The other is inline fuse just look around the battery for it, it could be anywhere.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 05-23-2012, 06:21 AM   #10
TURBS's Avatar
YOU cannot check battery level on indicator panel when hooked to shore power!
The converter will make it show full.
Although indicator will show General battery condition when UNPLUGGED from shore power.
Ilneed to use hydrometer or load tester
led pad
