You sure it`s not a square drive bit? that is usually the standard screwhead in RV`s. sometimes you can even get a phillips screwdriver to work.
Good luck.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
