Old 05-05-2012, 09:59 AM   #1
OH NO...deadbolt key broke!!
ok, perhaps I should have paid more attention to the DW when she said last night that I need to show her how to operate the lock on the door. We have had this camper about a month, new from dealer, and been working on setting it up.
Well, I go out today and was going to insert key in lock when I noticed the key looked funny. The cut part above one of the grooves had been squished down over the groove. When pulled up on it with my thumbnail, it broke. To make matters worst, this is the only key. For some reason I only one and I didn't realize it, so it was on my list to call dealer on (he is 2 hrs away).
I have called the dealer and they are looking for a key. They said I need to get the lock apart (really, I'm on the wrong side of the door for that) to get the key code. There is a code on the key and I went to RVlocks on web and they have precut keys to that code. This maybe my only solution but will take awhile.
Other thoughts? Drill out lock and replace whole unit as there are dealers closer but not Rockwood??
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 05-05-2012, 10:42 AM   #2
Twisty's Avatar
Order a key and have it sent overnite or 2 day. Cost may be about the same as taking it to a dealer or calling a locksmith.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-05-2012, 10:43 AM   #3
Rebel702's Avatar
Can u gain access thru an outside storage compartment?
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-05-2012, 11:05 AM   #4
JDWeir's Avatar
I had something similar happen to me on my new Sabre, the lock actually went bad and I broke both keys trying to get it open. My work laptop was inside and I really needed to get it out, thus the 2 broken keys. Of course, this was on a Sunday afternoon, so first thing Monday morning, I called my dealer. Ended up having a locksmith come and drill the lock at a cost of $90 then had to put in a new handle/lock assembly. I was lucky as all was covered under warranty, they paid the locksmith bill and sent out the new handle/lock and I installed it. They are not hard to install once you can get the door open
I did look for another way into the coach and I was not able to find any way in, all the windows were locked and no entrance from the basement.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 05-05-2012, 01:57 PM   #5
bikendan's Avatar
if you had a hybrid TT, you could go through the bunk end to access from inside. why do i know, cause i had a similar thing happen to me.
i was able to remove the lock/latch from inside.
but unless you can get in from a window, i think a locksmith is your only option.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-05-2012, 02:24 PM   #6
Rugged Brown's Avatar
Where is a burglar when you need one?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 05-05-2012, 02:32 PM   #7
I had the same thing happen a couple years ago. I drilled it out and ended up replacing the entire thing.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 05-05-2012, 02:53 PM   #8
Break the door window glass,unlock door. Cost to replace glass 20.00. Call locksmith 90.00 your call. Youroo!!
Old 05-05-2012, 03:56 PM   #9
caper's Avatar
You can drill out the key way. Most likely a 3/8 bit. Once the key way is removed you should be able to turn the deadbolt with a screwdriver. The lock will have to be replaced but will have less damage then breaking a window.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
caper is online now   Reply With Quote
Old 05-06-2012, 01:38 AM   #10
Rebel702's Avatar
Does the pass thru storage in the front also access under-bed storage? Mine does. Just push the bed up. (Need a small friend.)
EQ-4, 14,000/1,400
2006 Yukon Denali
