Old 08-01-2019, 08:54 PM   #1
Onan Generator
I have a 4k Onan that when you hit the start switch the starter engages and immediately disengages and sometimes ,after doing this several times, it will engage and start up. Batteries are good and fully charged. Anyone know what it might be?
Ronnie McCormack
rrmccorm is offline   Reply With Quote
Old 08-01-2019, 09:28 PM   #2
just guess. you said batteries are good. how about the cables and connections? are they are clean and tight? a bad connection can limit the power getting from the batteries to the starter. check both the positive and negative cables and grounds. again, this is just a guess.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-01-2019, 09:59 PM   #3
onetonford's Avatar
Could be a bad Bendix on the starter or a damaged flywheel. On small engines sometimes when the air filter gets clogged and it will cause this issue as the engine coughs and the Bendix drops out. I would check the air cleaner first and go from there.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
generator, onan
