Old 06-07-2016, 01:19 PM   #11
TURBS's Avatar
Op pm sent
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-07-2016, 01:19 PM   #12
7 Year Class A RV'er
So far as I can tell, our second AC is not ducted. It simply dumps into the bedroom, straight down on the bed (which is the preferred scenario from my wife at this time in our lives!). When only the rear AC is running, I do feel some very slight airflow through the ducts but I think it's just the pressure equalizing through the coach. If both were ducted and running at the same time, you'd have the airflow from each direction fighting one another inside the ducts.
2015 Legacy SR340 360RB
Old 06-07-2016, 01:26 PM   #13
TURBS's Avatar
Not true sir, you get more air flow!
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-07-2016, 01:27 PM   #14
TURBS's Avatar
Pm sent
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-07-2016, 01:38 PM   #15
TURBS's Avatar
There is NO difference between a ducted and non ducted a/c unit.
The things that make them ducted or non ducted are :
1) control module
2) ceiling diffuser
3) thermostat
4) cut outs in the atttic
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-07-2016, 01:45 PM   #16
AquaMan's Avatar
1) control module
2) ceiling diffuser
3) thermostat
2015 Columbus 320RS
2008 2500HD Duramax
I concur. If the OP is having trouble with the original unit not cooling the living area, he should open the bottom dump and forget the ducting until things cooled off.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-07-2016, 01:48 PM   #17
TURBS's Avatar
I believe his divider plate may have came loose such as mine did.
When this happens you get no air flow in the vents.
2015 Columbus 320RS
2008 2500HD Duramax
Old 06-12-2016, 05:42 PM   #18
Computer Nerd's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
Turbs is correct. I have two units and airflow increases when both units are on.
Computer Nerd
2014 Chevy Silverado 3500 HD Duramax
2016 Sandpiper 35ROK
Computer Nerd is offline   Reply With Quote
Old 06-15-2016, 04:14 PM   #19
My current fiver, 2015 Wildcat 327 ck, has two ducked ACs. They
both put the cool air into the same duck and it is very nice. When I had a stand
alone 2nd AC in the bedroom of my last fiver, it was noisy and very hard to control.
It is on or off. You could turn it up or down. After having that I new that only the two ducked units was the way to go in SE Texas. Good Luck
whj77372 is offline   Reply With Quote
vent
