Old 06-05-2016, 02:43 PM   #1
one a/c not sending air through vents
Hello. I have 2 new dometic 15's on my wildwood 408 reds. I've only had one a/c before and I would use a window unit when needed. With the one unit I would have a cold bedroom and bathroom but the big room (kitchen, living room, big left and right slideouts) would be warm. The a/c vents at the end of the rv hardly blew air.
Now I have two a/c's. The a/c that is mounted in the bedroom (never had one there prior) does not seem to send air through any vent when it is the only air powered on. When I have both a/c's on I feel a noticible difference of stronger airflow through the living room vents so the bedroom mounted a/c is doing something but when the bedroom a/c is on by itself there is no air flowing through any vent. I can open the vent adjacent to the filter and she will blow like a hurricane but with that vent closed she wont send air out of any duct vent but she will noticebly assist the flow through the ducts when both air are on.
Figured I'd post this before I get on the tech who installed the a/c's.
thank you
kdc1899 is offline   Reply With Quote
Old 06-06-2016, 11:31 AM   #2
anyone?
thanks
Old 06-06-2016, 01:15 PM   #3
Head Rambler
I'm not sure that the ducting on the two A/C's are tied together?
Does the other A/C blow air out the quick cool vents of the bedroom A/C when it's on?
Have you pulled the grill off the bedroom unit to see if it's connected to the duct work.
Gotta go campin!
Old 06-06-2016, 05:59 PM   #4
The local rv guy who installed it niw says that the unit is stand alone and not capable to be ducted.
Seems like a waste of money. The bedroom and bathroom were always cold with the single unit. The big room was always warm. I always had a $100.00 window unit that took care of that and still have to use it.
oh well.
thanks for y'all's time.
Old 06-06-2016, 08:26 PM   #5
I thought that most of 2nd AC units are non ducted.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-06-2016, 09:30 PM   #6
Live and learn I guess.
Old 06-07-2016, 12:39 PM   #7
CDR USN Ret
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
If both fed a single supply duct, when both were running, their fans would be fighting each other and very little air would flow.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 06-07-2016, 12:53 PM   #8
My new 2015 Rockwood TT has 2 a/c vents in bedroom and one not blowing cold air. Long story short, one of the vents was not connected from the factory. Hard to believe. I guess many would say "not really". Dealer did the repair no problem.
robbdrell is offline   Reply With Quote
Old 06-07-2016, 01:05 PM   #9
TURBS's Avatar
Not true whatsoever!
I have two ducted a/c units "I installed the second" and I doubled my air flow in every vent.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-07-2016, 01:06 PM   #10
TURBS's Avatar
oh well.
Are the a/c controls on the unit or do you have a thermostat?
2015 Columbus 320RS
2008 2500HD Duramax
vent
