Old 07-13-2017, 08:07 AM   #1
Outdoor Speakers Intermittently work
Hi,
I have a Heritage Glen 312qbud. The outdoor speakers intermittently work. I've had the radio replaced once but are still having the same issue. I'll be getting a 2nd radio this weekend. If it happens with this new radio again, what else could it be?
When it does work, sometimes the volume is really low (even if I have it at max volume) but then the volume fixes itself. After I shut it off and put it back on at a later time, sometimes it won't work. Could it be a wiring issue?
ijnasrallah is offline   Reply With Quote
Old 07-13-2017, 08:29 AM   #2
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
The "Easy" things to check ...
  • Make sure speakers are wired "properly" - they are NOT DC or Common grounded, so if the +/- pairs are not where they belong, stange things will occur.
  • Likely, the speaker wires are color-coded pairs between the radio head, and the speakers themselves (i.e. zip cord pairs with one of pair striped) so validating the proper pairings is easy.
  • check DC resistance of speakers - should be in the 2.5 - 3 ohm range for "typical" 4-ohm mobile speakers (expect 6-7 for house-type 8-ohm speakers.)
  • Repeat check of speaker impedance from radio end - you are looking for a short in the speaker wires.
  • Failing speakers - intermittent or burned voice coils - could give symptoms such as you report.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 07-13-2017, 09:13 AM   #3
Thanks. This trailer is new, so I'm hoping it's not the wiring. If this new radio doesn't fix it, I'll have to take it back to the dealer.
Old 07-21-2017, 03:56 PM   #4
Had one non working speaker on our new Lacrosse and found a bad crimp at the speaker. Who woulda thought that you needed to strip the insulation from both wires before attaching the connector?
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 08-21-2017, 07:44 PM   #5
Bene Gesserit Rule
Murbella7's Avatar
I have had the radio replaced twice and the outside speakers still failed. The problem is with the radio. I got fed up, replaced the whole thing with a cheap after market radio/DVD player and wired in my own switches.
Name:	TV & Radio 2.jpg
Murbella7 is offline   Reply With Quote
Old 08-21-2017, 07:56 PM   #6
crunchman12001's Avatar
I just discovered a similar issue this weekend. I thought I blew one of the exterior speakers.
I removed the speaker from the wall to find out the factory ran out of female spade connectors used to plug into the speaker. They had a connector on one wire and just bent the other wire into a "U" and slide it through the hole on the male speaker terminal.
I added a new spade connector, all is well now.
2015 F-250 FX4
door
