Old 12-28-2017, 05:54 PM   #1
Outside outlets not working???
Does anyone know why the outside outlet on my Rpod 179 might not have power?
beckham is offline   Reply With Quote
Old 12-28-2017, 05:56 PM   #2
Flybob's Avatar
Check GFCI. It may be in the outside outlet or in the bathroom or kitchen area. One GFCI controls several downstream outlets.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-28-2017, 05:59 PM   #3
What is GFCI
Also I just am seeing that no outlet inside is working either?
Old 12-28-2017, 06:02 PM   #4
U were right, than you!!
Old 12-28-2017, 06:15 PM   #5
Originally Posted by beckham View Post
What is GFCI
Ground Fault Circuit Interrupter - it's a safety device designed to protect you from electrical shock under certain circumstances.
https://simple.wikipedia.org/wiki/GFCI
johnbryanpeters is offline   Reply With Quote
Old 12-28-2017, 06:16 PM   #6
I mean , thank you
Old 12-28-2017, 06:17 PM   #7
Flybob's Avatar
Ground fault Circuit Interrupter. Should be an outlet with a set and reset button. Your last response seems to indicate you fixed it. Good Job.
TST Tire Monitors
2 100W solar panels
Old 12-28-2017, 06:20 PM   #8
Mr. Dan's Avatar
I suspect you got moisture in an outlet. That will trip your GFCI master outlet. Sometimes it's that outside outlet that gets wet.
