Old 09-22-2010, 04:12 PM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
Outside oval orange light replacement
Ok I know this sounds silly but both outside orange lights have burnt out. The one over the doors and the one under the steps.. I cannot for the life of me figure out how to get these domes open to replace the bulbs!! It looks the same as the light for the propane tanks but without a rocker switch.
So how does one get it open?
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-22-2010, 04:19 PM   #2
acadianbob's Avatar
Mine has a little notch in the amber lens. I had to replace a bulb early on. It made me a little nervous but you just have to compresss the lens a bit and pop it out.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 09-22-2010, 04:20 PM   #3
Dave_Monica's Avatar
There's 3 small tabs holding the lens in the housing...usually two on top, one on the bottom. Just gently pry the lens the housing with a thin screwdriver or scraper.
Dave
Old 09-22-2010, 04:21 PM   #4
The_Stuff's Avatar
okay. I will give it a try. I assume from the bottom? I just REALLY REALLY do not want to bust a lens!
Old 09-22-2010, 05:27 PM   #5
powerboatr's Avatar
x3 gently grasp it and squeeze it enough to pull the tabs back and off she will pop
its only scary the first time, then you will be amazed at the fact they don't pop off going down the road
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 09-23-2010, 08:30 AM   #6
Hipshot's Avatar
Yes they do come off going down the road. My amber lens departed the TT somewhere in north Texas. My local dealer stocks them for about $2.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
