After hanging around here long enough, reading many threads. You will find that the possibility of a factory wiring connection may be loose or installed incorrectly. You did not mention where you obtaining your signal from; OTA, Cable, or Satellite. I am guessing it is from the same source as living area tv. Which would indicate something is working up to a certain point. Also what RV unit do you have?
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
