Old 08-08-2010, 04:01 PM   #1
Outside Temp reading On Ford 450 Class C
We have a Class C Sunseeker with a Ford 450, it has a Mirrow with rear camera, compass , and outside temp reading. will the outside temp reads way to high, were would the sensor be located,and if it can be found can it be relocated
pasweet is offline   Reply With Quote
Old 08-08-2010, 04:24 PM   #2
Not sure about the 450, since you didn't say what year, but on a 2001 F150 it is located in front of the radiator, dead center, or almost. Has to get incoming air, from in front of radiator somewhere. If you have had radiator work done, probably not put back in the right location. Hope this helps.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-08-2010, 04:33 PM   #3
The Motor home is a 2010, with a 2009 Ford 450,
