05-19-2019, 05:51 PM
Overdrive use
My 2005 Lexington 255 GTS has the Ford V10 and a transmission with overdrive.
Is it okay to drive it in OD under normal flat land driving conditions . I would suspect that non-overdrive would be used in the mountains or long grades or towing ‘heavy’ loads. I sometimes flat tow a Smart Car (1800#) in OD and it doesn’t even seem to know it’s back there....
Comments
Bill
05-19-2019, 08:21 PM
Put it in OD and go. Tow/haul will alter shifting. If no Tow/haul then use drive in hilly country.
05-20-2019, 04:07 AM
Thank you
Bill
05-20-2019, 10:52 AM
Broken Toe
Just some info...
OD is not some "attachment" or "component" in your transmission. It just indicates that your output shaft (driveshaft) spins faster than input shaft (engine). For the longest time, the highest gear in cars and trucks were direct drive (both shafts spin the same speed). Nowadays, the top gear is 'overdriven' and some manufactures like to tout it by indicating it as 'overdrive' on the selector instead of just 'drive'. The top two gears in my GMC terrain 9 speed are in fact overdriven.
I remember years ago friends who would shift out of overdrive into 3rd gear in the city because they didn't want to "burn out their overdrive". Just put it in Drive or Overdrive or whatever its called and let it go.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
05-20-2019, 11:22 AM
Originally Posted by Cowracer
Just some info...
Tim
Except in the OP's case it sounds like his F53 chassis has the overdrive button on the end of the gearshift lever. When pressed, as I remember, OD OFF will be displayed (illuminated) on the instrument panel display. Overdrive is not a selectable choice with the gear selector. I typically would disengage OD for steep downhill runs.
05-20-2019, 11:37 AM
PPST Wannabe
No guarantee here, but I believe the OP has a Lexington which is probably based on a Ford E350 or E450 platform, not an F53 as in Class A units.
My transmission INCLUDES overdrive, but there’s no way to just turn it off. The selector shows. P R N D 3 2 1.
The button on the end of my gear selector is for tow/haul.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
05-20-2019, 12:11 PM
It indeed is a V10 E450 cab/chassis with the OD on the end of the stalk. Pushing the button will display an OFF light and the engine rpms will go up significantly
Compared to my Rialta it is a gas hog and I wondered if OD might lug the engine and contribute to its thirst.....
Bill
05-20-2019, 01:01 PM
OK, same scenario for his year platform, whatever it is. Didn't have tow/haul mode then. Procedure the same as stated.
Additional. F53 chassis was the same then also.
05-21-2019, 12:59 PM
Broken Toe
No matter how it's done (button, lever, etc) when you "turn off" overdrive, you are simply telling the transmission not to shift into its top gear.
My advice to anyone is put it in D or OD and leave it. The transmission is plenty smart for figuring out what gear it should be in. As far as downshifting on hills... Well, its always been easier for me to change brake pads than transmissions.
tim
05-21-2019, 01:04 PM
Broken Toe
Your "Drive" gear is an overdrive. I guess back in the day when they first came out, manufacturers like to tout that they offered "OVERDRIVE!!!™". Now that practically everything including my lawn tractor offers overdrive, they just call it "Drive". Like I said... My GMC terrain has 9 speeds, two of the are overdriven, and my gear selector only has a "D".
Tim
