Old 08-23-2014, 08:42 PM   #1
asquared's Avatar
pantry gets really hot
On my 34REQS the pantry is located on the slide just next to the fridge. I have noticed it gets really hot on my top two shelves. Hot enough to melt chocolate bars and make food packages warm to the touch. What can I do to help keep the cabinet cool? Thanks
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-23-2014, 08:55 PM   #2
miatared's Avatar
We have a 31REDS and have the same issue. Bottom shelf mostly, water heater is underneath, right next to the fridge with the furnace underneath....
Not sure what can be done, short if moving the food elsewhere and move blankets & jammies in there ☺
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 08-23-2014, 09:07 PM   #3
mark0224's Avatar
I'm thinking the heat is coming from the fridge which you probably already figured out.
This might help remove some of the heat in behind the fridge. Amazon.com: Camco 42165 Refrigerator Solar Roof Vent System: Automotive
Will have to look into this on my own our pantry is above the furnace and beside the fridge, haven't had to use the furnace yet.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 08-23-2014, 10:53 PM   #4
asquared's Avatar
I would love to use the solar vent fan but not sure how it will work for us as our fridge vents out the side and not the top.
2014 Sabre 34REQS-6
Old 08-24-2014, 08:00 AM   #5
mark0224's Avatar
Here's 2 other versions that I think is more for your type.
Solar
Amazon.com: Camco 42162 Solar Panel and Fan for Refrigerator Vent: Automotive
hard wired
http://www.amazon.com/Valterra-A10-2...ridge+vent+fan
hope one of these works.
Old 08-24-2014, 08:10 AM   #6
NELA
Weezer's Avatar
All of our upper cabinets get very warm. I saw a video a while back where a guy with a class c used and laser thermometer to show the temps in his upper cabinets, then he lined them all (sides and top) with reflectix (the foil bubble wrap looking stuff) and then used the thermometer again. IIRC the temp dropped at least 12* in those cabinets.
I'm going to do this, as soon as get a "round tuit". I'll just use double backed tape like he did.
Actually I have already priced a big roll of it at Home Depot. Gotta get Sneak to *force himself to go to Home Depot* (eyeroll) and pick it up for me.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-24-2014, 08:14 AM   #7
asquared's Avatar
Thanks Mark, I will check these out.
Weezer, I'm assuming they mounted these inside the cabinet. I might try that as well. We were questioning if the issue was the sun beating on the slide.
2014 Sabre 34REQS-6
Old 08-24-2014, 08:18 AM   #8
NELA
Weezer's Avatar
DUH....yeah....silly me, should have said that. LOL
I'll find that video when I get home.
Old 08-24-2014, 08:23 AM   #9
We mounted a computer fan ( with alterations ) to the freezer section and tapped a power source so when the fridge is on so is the fan. Works fine and also keeps the fridge temp down also.
dblr is offline   Reply With Quote
Old 08-24-2014, 08:31 AM   #10
CCRVOC
Ramblin Recks's Avatar
Our pantry next to the refer (in the slide) used to very hot as well. The issue is the rising heat that can not escape in the refer "box". I built a curved baffle out of thin roofing flashing behind the top of the refer and installed two high cfm fans to push the air out of the top vent in the slide. It made a huge difference, refer and pantry is much cooler .
This instruction states how the refer is supposed to be vented.
http://bryantrv.com/docs2/docs/dometicventing.pdf
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
