We've never had the opportunity to try the Park Cable hook up for park cable but have that option at some CGs on our trip to Utah. We have miles of satelitte cable for the Winegard carryout. Will that work?
Karen
Enjoying the great outdoors with one hubby and 2 boxers!
just bought a 2008 rockwood fifth wheel, when connected to cable at the park is there any particular switch that has to be turned on or is it just connect and thats it? Tried at one park and TV never recognized any connection? wonder whats wrong?
wayne
When connecting to a CG cable connection, connect your outside cable to the right side cable connection of your exterior cable jacks. Make sure your TV is connected to the cable/antenna interior jack and make sure your antenna booster is off. When the light is off, the booster is off. Believe me this works because I just recently ran extra satellite cable to the front bedroom, garage, and extra jack for outside viewing.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
I wish you had posted this 2 weks ago, as I spent 3 hours trying to get the cable working. CG office kept telling me the cable was working, I swore up and down that it wasn't. I left the booster on and this prevented the tv from getting the cable signal. One more thing, if the booster is off, can I plug my satilite in to the jack that is labled "cable". I only have a cable input.
Bill
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bill
We aren't able to although from what I've read in other threads some people can. Ours is "satellite ready" which means it has cables run from the roof into the cabinet where it would connect to the receiver.
I knew that about the booster but whether I would have remembered or not is another story!
Karen
No...satellite has to go into the satt input and cable into its input. Drove myself crazy one afternoon finding that out the hard way. I use a portable tripod for dtv but if the CG has cable I will use that to get local channels and a break from setting up the tripod. Like others said, the power to the antena should be off and the telev changed to cable and allow it to scan for channels. Have fun!
sat receiver must be able to pass DC voltage to the dish. the cable connection (on mine) doesn't. the frequency band is also a little different. (my cable passes thru the winguard wall plate).
unless u have a switching set up that i'm not familiar with...no.
r6 cable is r6 cable, how would the direct tv reciever no any different? I had cable at my house, then swithed to direct tv, and I didn't have to make any changes, the tvs are still hooked up to the same connection. So I don't see why it would be any different In a camper. Just curious. You are right jimh about having to pass DC voltage to the dish, I'm just trying to figure out why you still couldn't with a cabe hookup.
you can if u remove that connection from ur winguard switch box and run it straight. the winguard contains a splitter to supply two tv's. splitters isolate the inputs (block the DC). they also need to be able to pass 950 to 2250mhz. i don't think the winguard splitter goes that high.
Oh I got ya, I don't have a winguard, I use a round 18" satelite on a tri pod im going too run the coax to the connection on the outside of the camper labeled "cable" because my current 5ver dosesnt have satelite connection I traded in my 2004 8528ress and it did. I have not got to take this one out yet because my boss at work thinks it's more important to go to work hmm now you got me wondering. If it will work, but I do have splitters in my house..
Thanks for the diagram, I see now, I guess you have to rewire it then. Hmm well at least I found out now instead of when I was allready at the camp ground.
