Originally Posted by Schwing2008
I have just purchased a new Georgetown 350 DSSE and I have 2 outside park cable plugs - one on each side of the motorhome in the storage compartments.
The issue I am having is I can not hook up Satelite TV to these park cable plugs as I get no signal.
Supposedly there is a splitter connecting the 2 park cable plug into one coax cable. The question is where??
Any ideas anyone.
I resently fixed by cousin's 340TS, 2008 Motor Home with the same TV problems, poor reception on either Ant. & Cable. After wasting time and fuel taking the RV to their dealer's service department, he called me to fix the system, know that I had to fix my own Hartland 5th wheel having the same issues. Having camped and RV'd for over 40 years I have always done my own repairs and solved and fixed other RV'ers problems as a hobby.
As a RV'er you have to understand; that very few of the RV companys, their engineers, assemblers, dealers, or repair people have ever camped in a RV over a week in their life. They have not had to make the TV work, fill up the water tank, drain the tanks, figure out why the refrigerator or water heater won't stay on. For sure, they have never had to make 4 trips to a Dealer's Service Department to be belittled and told "they fixed it this time.
RV companies and their engineers & designer like to sucker you in by hidding all the systems under petty panels and behind cabinets,etc to my the RV
PETTY and
Hard to Repair. After I first bought my Bighorn trialer; I remove every panel that was hiding systems, and threw them in the trash, because I want to see everysystem, look for leaks, and get at and repair problems quickly. Removing panels in my storage area also gave me more storage space.
After looking over my cousin's RV, I started reading the forums about Forest River RV's to learn about them and common problems. I found that many owners have TV system problems and that Forest River will not sent out Wiring Skumatics for their products to owners, which is assinine!
Everyone owning a RV should have drawings of all systems. Also Forest River likes to hide all the systems, especially wire so that you can't find parts, such as spliters, etc!
How Forest River's TV system on the 340TS works-------
1) Park cable hook-up is in storage cabinet a dirvers' side back end of RV.
2) The other plug on the passener door side in the storage area is for
plugging in a outside TV on the patio.
3) The antena cable and cable from the connection at drivers side rear both
go directly ( hidden under the floor & behind panels) to the cabinet holding
the cover plate with the green lite & push buttom for antena power or
cable. The 3rd cable behind the cover and hooked to the green light
switch goes to a 3 or 4 way splitter. One cable out of the splitter goes to
front TV, second cable goes to the bedroom, and 3rd goes to the outside
storage bay on door side.
4) The splitter was buried or sandwiched in space under the cabinet shelve
holding the DVD player. I had to tear the bottum out of the cabinet to
reach the splitter and conections. Later had to rebuild the cabinet (I am a
master carpenter / mechanic).
5) As I have found in the past, the RV companies use cheap cable end
connectors and their employees do not prep (strip) the cable wires
correctly and then do not crimp the connectors to the wires properly!
6) I restripped every cable end and preplaced every crimp connector with
expensive quality connectors. Cousin now has an exceptional picture on all
TV's weather antenna or cable.
7) I also made up a 30' park cable with quality cable & connector for his use.
I hope that this helps.
