Old 10-21-2014, 12:32 AM   #1
Part # for air compressor fitting on hot water tank on georgetown 351
First winter for me and I need to winterized my Georgetown 351, what is the male valve for air compressor fitting that goes into water heater?
tfebb17 is offline   Reply With Quote
Old 10-21-2014, 06:25 AM   #2
TURBS's Avatar
The air fitting does not go in your water heater.
It screws on to your city water connection.
Any rv store or even walmart has the fitting.
It may be plastic or brass.
Turbs
Old 10-29-2014, 11:08 AM   #3
iowasparrow's Avatar
Amazon.com: Camco 36143 Blow Out Plug with Brass Quick Connect: Automotive
iowasparrow is offline   Reply With Quote
Old 10-30-2014, 07:27 PM   #4
Make sure you turn the regulator down on the compressor. I use about 30-40 lbs to blow out our fifth wheel. Don't want to damage the plumbing.
bubbubouy is offline   Reply With Quote
Old 10-30-2014, 07:55 PM   #5
j2detroit's Avatar
these work great just a quick fyi I did find a wand that you attach to a garden hose and use to flush out the water heater I just got it this summer and used it for the first time when I closed up this fall my camper is an 06 and I have never done anything but drain out the water heater before WOW did I get a lot of scale out of it with that wind I'll do it again next spring when I open it up for the season it should really help it work well
j2detroit is offline   Reply With Quote
georgetown, hot water, tank, water, water tank
