Old 01-22-2011, 06:26 AM   #11
Herk7769's Avatar
The Xbox is gone now. I knew it was a dino when it was put into the camper so it was the only thing wired "outside" the woodwork. We just did not use it that much. The PC, my laptop, and DW's iPad provide all the gaming we need. (Although I could be talked into a Wii (or Wiii )at a later date).
HAM CALLSIGN - KC3FFW
Old 01-22-2011, 07:01 AM   #12
SoundMan's Avatar
Originally Posted by scubieman View Post
I show you have VGA out on your computer, The best bet would to connect VGA from computer to tv. The problem is getting the sound to the tv too. I would say it's almost next to impossible or too expensive. You would be better getting a laptop with HDMI out.
There are VGA w/Audio cables available it has a mini1/8" at each end.
I'd rather seek forgiveness than ask permission
Ford Excursion Eddie Bauer 6.0 PSD
2006 Ford F350 6.0 PSD QC King Ranch
2006 Titanium 36E41MPRV Loaded
SoundMan is offline   Reply With Quote
Old 01-22-2011, 07:22 AM   #13
SoundMan's Avatar
Originally Posted by JDickson View Post
Terry thanks for your answer I'll try that and see what happens.
Lou I think I understand your point, if I have a 72o or a 1080 both have to match. Thanks to both of you for your time and answers.
I'll wait 2 or3 days to see what if any other answers I may get before I try anything, I already had to dowload new drivers to straighten my computer once, I'll wait before I have to do that again.
I'm just glad to have so many smart people out there to ask.
Joe
Have you been able to get your TV and net-book working? I own an pro audio/video installation co. and convergence issues can be challenging. If your TV has a VGA/RGB connector you should be fine. As previously posted all you need to do is change the aspect ratio. Look at your TV remote it will say aspect ratio or wide.
Old 01-22-2011, 07:24 AM   #14
Thanks Lou, yes I am using the 15 pin adapter from the netbook to the tv.
The adapter I'm using also has a single sound wire, but it's to large for where the audio sound out port is. So if this information helps you to explain to me how to make it work great. I too am connecting to a 32 inch Olevia tv.
Thanks again.....Joe
JDickson is offline   Reply With Quote
Old 01-22-2011, 07:41 AM   #15
SoundMan's Avatar
Good Morning
Your audio cable needs to be male stereo 1/8" mini at the computer side with two RCA male at the TV side.
Old 01-22-2011, 08:06 AM   #16
Herk7769's Avatar
If you look at the second photograph (of the back of the TV) along the bottom of the TV (not the side) you will see a row of cables.
From the "right" they are: HDMI cable from the Upconverting DVD player located on top of the PC; the RGB 15 pin video cable from the computer; the red and white RCA plugs from the left and right channel output from the PC using Ziotek 6ft. Mini 3.5mm Stereo Cable Male to RCA Male ZT1900370 - Cyberguys.com; and the power cord.
Old 01-22-2011, 10:17 AM   #17
Send a message via Skype™ to scubieman
Quick side track question for Lou, what do you use your computer for? Won't a laptop be easier?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-22-2011, 11:00 AM   #18
Herk7769's Avatar
It is my audio visual center. I built it custom for the camper.
Very tiny; very high-end.
I also use it for work. I write aviation training software for an Air Force Contractor who then repackages it to sell to the AF. (I do ok... )
