Old 01-07-2010, 04:42 PM   #1
Pergo or allure flooring winter storage
Hi out there has anyone experience with the above flooring types ability to withstand subzero winter storage.
I'm considering installing it to replace split linoleum/vinyl flooring in the galley area of my 2004 Georgetown 34DS - the spliting was as a result of the same winter storage conditions.
ChrisD
ChrisD is offline   Reply With Quote
Old 01-07-2010, 05:02 PM   #2
powerboatr's Avatar
i put allure in our previous fiver...but i never left it stored in freezing weather
I had great service from the flooring over all
in fact i installed it in freezing weather but the coach was warm 70F
i would think that if its freezing in the coach you might want to do a warm up with the heater prior to walking on it or driving around that might make it flex.
I think freezing temps on any vinyl floor product is pushing its reliability
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 01-07-2010, 06:12 PM   #3
NWJeeper's Avatar
The Bruce laminate flooring in our old rig has seen down to around zero F but that's about it. We always keep a small space heater going in our rigs and keep the temps close to 50 during the winter to avoid problems with those kinds of temps. The added expense on the utility bill is well worth it to me to avoid problems with our expensive RV.
Ed & Wendy
www.nwjeepn.com
Old 01-08-2010, 06:55 AM   #4
MtnGuy's Avatar
I would be interested to hear what acadianbob has to say about his trailer and sub-zero temperatures, and what precautions be takes. He had -20 a couple of nites recently.
If the temperatures get into the single digits here, I run a heater on low so hopefully I won't have a problem.
Old 01-08-2010, 09:53 AM   #5
acadianbob's Avatar
we've not had a problem. our trailer is an '08 so this is its third winter. it regularly sees -20 and the occasional -30; sometimes for a week at a time. it is stored inside in our barn but un-heated. thus far, no issues of any kind. trailer is a surveyor.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-08-2010, 09:55 AM   #6
acadianbob's Avatar
the only thing i do is the standard winterizing of the water lines; drained tanks; disconnect the battery and hook up a battery minder. nothing special and no heat of any kind.
