Forest River Forums
Sunline User Photos
Old 09-07-2011, 05:59 AM   #1
Permanently removing water filter
Has anyone removed the water filter permanently? How did you do this? We have a Surveyor 264. The water filter is almost impossible to get to. We always use an external filter and also filter drinking water with a Pur pitcher filter. Our trailer sat for a good bit of the summer and now the water seems to be contaminated. Looking at the filter confirmed this in spades. I want to get this thing out of there for good!! Anyone have any experience? Thanks.
irene l is offline   Reply With Quote
Old 09-07-2011, 06:09 AM   #2
cardinal4fun's Avatar
Once you unscrew the lines from the water filter housing you should be able to use a coupler to join the two lines together. I would get a few different size couplers 1/2, 3/8 etc.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 09-07-2011, 07:39 AM   #3
volunteer moderator
I also didn't want my "built in" filter. It was hard to reach and impossible
to drain without spilling in my crawl thru storage.
I simply unscrewed the pipe thread tubing fittings from both sides
and connected them together with a brass pipe coupling.
I tried a PVC threaded coupling but it would drip slowly no matter how much
teflon tape or pipe dope I put on the threads. It finally split due to over
tightening. Brass is the way to go.
Sorry, I can't remember if it's 1/2" NPT or 3/4 NPT.
Good Luck!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 09-08-2011, 06:16 AM   #4
Lou Amadio
herk7769's Avatar
Mine was hard to do since they used permanent PEX connectors. They could not be unscrewed from the housing without removing them.
I had to use a plastic pipe cutter to cut off the fittings and then remove the housing. I replaced the PEX fittings with push type Gator fittings and installed a Shurflo air bladder in its place.
File Type: jpg 913th 3rd Annual Picnic and Camper photos 037.jpg (50.8 KB, 7 views)
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 09-08-2011, 07:39 AM   #5
jimh's Avatar
i used a fitting in a hard to get area called a shark bite. basically push it on and it seals. to remove, u insert a tool from the back to release it.
seems that i read in their literature that the "O" ring had a life expectancy or 5 or 10 yrs. is this the same thing?
the fittings weren't cheap (~$15) but worked well. no glue. also forgave minor imperfections in the pipe. the time savings was unbelievable.
jimh is offline   Reply With Quote
Old 09-08-2011, 08:21 AM   #6
Lou Amadio
herk7769's Avatar
http://www.lowes.com/pd_292772-2140-...%7C1&facetInfo
Gatorbites work the same way.
Old 09-09-2011, 01:21 PM   #7
Thanks for all the responses. A free-lance tech came to our campsite and replaced the filter with a coupler/connection in about 10 minutes. No leaking either!! We are HAPPY.
» Online Users: 666
146 members and 520 guests
11XLITE28BH, 64c10, alphadog99, alpinemike, BeagleIL, Bigmatt, bikendan, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Cascade Bob, cdbus, chof16, ChrisZazzara, Cowracer, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, dapersico, davidjb, depo, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, dunnnc, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, feerobk, Fire Instructor, Flashg_123, Foneguy, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gmw65, grhodes50, Hamblen, HemiCab, Hilgy, hotrodj125, Itsthetwoofus, Janet H, jar3316, jjm901, jkinger, jmswms, jobren4, jrb988, Juan.Cortes, ken0042, Kevin-and-Julie, KoolAide, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, Loopyhamil, LuckyMcBRIDE, mbfree66, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, mike54, Mrgary, NINA, Nursx2, PAMROBERTNC, papap, pgordemer, phone man, Piston, Playtime III, pmsherman, popbreed, Poppy Bill, Ptmaazx6, punkaccountant, pwadini, RattVader, rbrandon, redfox217, Redheaded blue tick, Retired63, rgmiller32, rick51, RJHuser, rob2112, rotorhead1250, SabreSam, Sahgie, Sailfish Bret, scroses40, SDENN4281, shane1234, shavard, shrimper, sideout1961, SimchaSabre, skullskidr, snjparham, Snowsail, T.Kott, TacBear, Tee, Test Account, texashatter, Timex, Titleguy, tmmar, trailraider, travyp, Triguy, True Believer, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, washdweller, wayne anthony, wellcoman, whj77372, wnytaxman, y01lxb
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
