Old 10-26-2013, 08:07 AM   #21
Originally Posted by jevanb View Post
I use my wife to level the coach, when she says it is level with her super sensitive leveling ability brain then I am good, it does not matter what the big level says on the front she is right ..lol
This cracked me up! My husband swears I am more accurate than a level. I guess I have a good eye for it
melissa16 is offline   Reply With Quote
Old 10-26-2013, 06:52 PM   #22
dcheatwood's Avatar
My wife could care less and wouldn't notice a 45° angle. Drives be crazy if water doesn't run straight to the shower drain.
2018 Forester 3011 DS
Old 10-28-2013, 12:32 PM   #23
Dallas Texas
TexasBBQ's Avatar
I know what you mean.
Thanks for all the ideas. I'll have to experiment. The thought about using the counter may not work well with me since all my counter space is on a slide. I know the slides are supposed to be close to level but I'm not sure how close is close.
The floor near the center (lengthwise) seems like it would work since it's mounted to the frame.
For grins I'll contact FR to see what they use.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 10-28-2013, 01:09 PM   #24
ARLO
Levels
I use a torpedo level to get it close and two stick on levels to finish the job. Stick ons work well as you are able to tweak them when the wife is not looking.
rlocicero is offline   Reply With Quote
Old 10-29-2013, 05:26 PM   #25
Dallas Texas
TexasBBQ's Avatar
Feedback I got from FR tech help is to use put the level on the floor....
I'll do this and once level I'm going to check it against the couter and frame from below. Now I'm curious what will match up.
2004 Cardinal 33CKT
Old 10-29-2013, 10:37 PM   #26
Professional Curmudgeon
wrvond's Avatar
Looking forward to your findings.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 11-03-2013, 12:37 PM   #27
Stg1's Avatar
I have an aluminum sided TT. I use the Hoppe curved bubble levels. I generally put the levels on using the siding as a guide and a 4' carpenter's level. This works well for side to side. For front to back, I use the 4' level a couple feet inside the door. I plan on putting at least one of the curved bubble levels on the side of the TT at the front for an easy check point.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
cat
