10-25-2013, 12:40 PM
Dallas Texas
Placing new Level indicators
As I was leveling the coach a couple weeks ago I tapped on the level as I always do to (I have the cheap OEM short glass tube with no curve) to settle the bubble and the whole thing dropped to the ground.
My daughter started laughing because it reminded her of the Sprint commercial when a part of the Zombie's ear fell to the floor. At first everyone just stood there looking like - now what.
So, I need to get the coach level from left to right side (not length ways). Where would be the best reference to place the level? On my 5ver the kingpin framing is all enclosed.
Bill
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
10-25-2013, 12:58 PM
Hawksclaw554
Service tech at dealer brought out two little bubble levels that look like they cost all of 50 cents the had the stickum tape on back and little screws to hold them on. Then forgot to install them after PDI. Noticed them in the basement when I got home. Any ideas on something better then this and proper location to put them would be appreciated.
10-25-2013, 01:20 PM
There might be a more technical answer, but I just set a small 8" carpenters level on the floor of the coach. Using this method I know that the fridge is level and also we won't be sleeping with our heads going down. I use the same level that my Dad used between 1960 and 1990 and it seemed to always work for him and it's been working for me now.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
10-25-2013, 01:30 PM
Bill
as in a cover??? do this if it is. I made this for mine
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
10-25-2013, 04:12 PM
Always Learning
Right, but I think his question is- where/what does he use for level before mounting a new one.
Heck, I have the same question- we use the floor inside of the door and I can change how level we are by simply moving the level itself.
10-25-2013, 04:28 PM
Put the level on the counter and when you're satisfied, put the attachable levels in a convenient spot you can see from the tow vehicle.
10-25-2013, 05:14 PM
Professional Curmudgeon
My owner's manual says to put a small level inside the fridge and level left to right then front to back. Once level all around install a couple of those new huge levels in easy to see locations.
That's not to say the counter top won't work; it's a darn sight better than the floor!
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
10-25-2013, 05:23 PM
Actually, using the floor next to the door works pretty well. I can just peek inside the door without actually going in and check the level. Like so much we do, it's personal preference.
10-25-2013, 05:37 PM
Not all campers enjoy a level floor, especially in front of the entry door. Incorrect use of stab jacks can tweak the door frame and outriggers which will give a false reading. While it would seem levelling is intended for our comfort, we can sleep in an unlevel camper. What we can't do is operate an out of level fridge (for the most part). It makes sense to set your initial, or reference, level based on that. But as you say, it all comes down to what works for you.
10-25-2013, 05:41 PM
Always Learning
I don't put down my stab jacks until after I've leveled side to side and front to back. It seems like you'd be risking damage if you did it before...
10-25-2013, 05:47 PM
After I level, I set my stab jacks too. It's a good thing you noted that for the sake of newbies that might think that you can level by using them.
10-25-2013, 06:06 PM
That's exactly what I was talking about.
Setting stabs is the last thing I do, as well. I was referring to the cumulative effects of improperly set stabs. My first TT was used and suffered from a tweaked door and outriggers. Additionally, I have seen this condition on many campers. Something else worth noting is longer Lippert frames seem to be susceptible to sagging at the ends.
Sorry for any confusion.
10-25-2013, 06:35 PM
If your counter is not good enough to determine level, I would be re-leveling the frig. The newer refrigerators are not nearly as sensitive as the old ones were.
10-25-2013, 06:46 PM
I leveled using the bottom of the refrigerator as suggested by someone here and then checked the counter and the floor.
The counter was the same as the refrigerator, the floor had a little more front to back tilt.
10-25-2013, 07:12 PM
Didn't suggest it wasn't good enough. Just the opposite, in fact. I merely cited a reference that recommended a different spot and the logic behind it. I still believe the floor isn't always the best choice.
10-25-2013, 07:24 PM
I use the free "bubble" app on my smart phone. Lay it on the floor and see which way I need to go left to tight. Place ramps under tires if needed, then adjust hitch to bumper after disconnecting. Audible beep let's be know when it level.
2018 Forester 3011 DS
10-25-2013, 07:30 PM
2X..I level the same way........
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
10-25-2013, 07:35 PM
Bottom line, you can level on the floor, across the bottom of the trailer, bottom of a 5er overhang, front tongue or along the trim on the side and it will be plenty close enough for the refrigerator. It's just what you feel good about doing. It's not a super critical item.
10-26-2013, 06:12 AM
I use my wife to level the coach, when she says it is level with her super sensitive leveling ability brain then I am good, it does not matter what the big level says on the front she is right ..lol
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
10-26-2013, 07:08 AM
for short days I use the bathroom door. I open it half way making sure it stops then I let go, depending on which way it moves and how fast that side needs brought up. Then I use the dogs ball set it on the floor and if it rolls the front either needs to go down or up. but for longer stays out come all the stabilizers, the 15 # dog can really make you seem like you are on a ship.......
