Old 03-10-2016, 11:21 AM   #1
Please help all my 120v gone!
I have a 2016 rockwood micro lite 21fbrs.. All my 120s are gone and no repair shop will take me in. I checked the fuses in the little box by the door. They seem good. I don't know what else to do...
No1up is offline   Reply With Quote
Old 03-10-2016, 11:25 AM   #2
TURBS's Avatar
Check the main "breaker" not fuses.
Where are you plugged in at?
Home ?
Recently installed shore power box?
Do you have a volt meter to check power coming in?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-10-2016, 11:26 AM   #3
Have you checked your circut breakers, maybe tripped the main breaker ???
Kevin & Judy is offline   Reply With Quote
Old 03-10-2016, 11:27 AM   #4
Berkshire 390QS
NO3putt's Avatar
The 120v uses breakers, not fuses. Have you checked your breakers? don't have a unit like yours so can not tell you where your breaker box is located.
NO3putt is online now   Reply With Quote
Old 03-10-2016, 11:31 AM   #5
Don't know if this is related but I have a 322RLDS Freedom Express Liberty Edition and I have now unexpectedly lost all 120v power a couple of times.
Absolutely NO rhyme or reason to it, it just all goes out, once with just the TV on, another with the AC and other stuff running while making dinner. No breakers are tripped, no fuses blown, GFCI didn't trip, just no 120v power anywhere in the trailer. 12v however continues to work.
What I did to resolve mine was turn off all my breakers, unplug from shore power, let it sit for 15 minutes or so, reconnect shore power, and then turn on all the breakers one at a time.
Mine is headed back to the shop/dealership tomorrow to finish the warranty list from last fall and will be adding this as well as a dozen other NEW issues to the repair list.
2016 Coachmen Freedom Express Liberty Edition 322RLDS (Sold)
2017 (SOB) Jayco Eagle 330RSTS
2015 GMC Sierra 2500HD SLE Gasser
blujay40 is offline   Reply With Quote
Old 03-10-2016, 11:33 AM   #6
wmtire's Avatar
What are you currently plugged into to get 120 volt AC power from? (house, campground, generator, etc).
Not knowing your RV expertise level, this is a good link for first timers (which you may not be by far)?
http://rvservices.koa.com/rvinformat...lectricity.asp
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-10-2016, 11:43 AM   #7
120 power gone
Since you have likely tried everything else try tripping and resetting the GFI.
DocRob is offline   Reply With Quote
Old 03-10-2016, 11:50 AM   #8
x 2 on the GFI's
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 03-10-2016, 11:52 AM   #9
Your main panel should be under your fridge to the left, check the main breaker. Check the breaker for the source you are plugged into. Ideally get a Voltmeter and verify electrical at the panel you're plugged into. check the GFCI which is likely in the bathroom.
foretm is offline   Reply With Quote
Old 03-10-2016, 11:55 AM   #10
Left Coast
Overheated power cord or plug.....
