Old 05-15-2010, 08:21 PM   #1
Please Help!Can't get power to new Rockwood popup
Just got a 2010 Forest river Rockwood 1640 LTD, We set camper up in our yard and ran an extension cord to Campers 15 amp adapter. All fuses are good no outlets in camper will work.Is my house not enough to power my camper? Or am I doing something wrong? Thanks for any info!
rio69 is offline   Reply With Quote
Old 05-15-2010, 09:21 PM   #2
NWJeeper's Avatar
Welcome to the forums
Seems to be a common question around here lately. Check to see if you are plugged into a GFI outlet in your garage. RVs sometimes don't agree with them and they will continually trip. Try another outlet.
Ed & Wendy
www.nwjeepn.com
Old 05-15-2010, 11:37 PM   #3
I had a Fleetwood/Coleman pop up, and it had a small plug in 2 pin wiring connector that supplied power to the roof section from the base section. It came unplugged before and caused that. Also, the Coleman had a swing away galley with a push in switch that allowed the power to turn on when swung into place. Check for any similarities from these. Good luck, Randy
