Old 07-25-2015, 09:26 PM   #11
Jimmerinwi's Avatar
Originally Posted by Wolverine 1945 View Post
Ford dealership,,, would be a great choice !!!
And an expensive choice. I think dealers prices are way overblown.
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 07-26-2015, 06:59 AM   #12
Wolverine 1945's Avatar
Your probably right Jim,,,
Not sure what they would charge for a MH,,, It seams our local Ford dealer always has a oil change special of cars & light trucks,,, I am thankful I am still able to do our own,,, I do not have much trust in those oil change places !!! I use mostly Mobil One,,, because Sam's has it for a pretty good price,,, 6 Qts for about $32 I think ???
Wolverine 1945 is offline   Reply With Quote
Old 08-01-2015, 10:02 PM   #13
On most Ford's it's right on the oil filler cap as to what weight oil to use.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 08-02-2015, 05:30 AM   #14
I believe you are right rg,,, but it only shows weight,,, which I think now is all 5 w 20 !!! at least it is on my V8 - V6 & V10 !!! Last I heard Ford was shipping all new cars & Trucks with Motorcraft Blend !!!
At least if I were to take one of my Fords to the dealer for an oil change,,,
I would not have to wonder what type of oil they might be adding !!!
And that they are smart enough not to over fill !!!
Old 08-10-2015, 09:58 PM   #15
Tfort's Avatar
The usual oil weight for a ford newer than 2003-04 is 5w 20. The use of petroleum or synthetic is a mater of choice. I have worked in a ford dealer for years and they are all good oils that will provide good results. My personal preference for oil is Amsoil because I run everything I own "until the wheels fall off" and full synthetic will give that long lasting performance. Just remember that there is only a few oils that are true full synthetic. Amsoil Mobil one royal purple are the big names that can be trusted.
Tfort is offline   Reply With Quote
Old 08-11-2015, 06:26 AM   #16
I Mainly use Mobil One in all of my engines,,,
I did have a lawn tractor mechanic tell me a couple of years ago that the engine manufacturers said there was no advantage to using a synthetic in a lawn tractor ???
I use it anyway !!!
Old 08-11-2015, 08:30 AM   #17
Jim Schings's Avatar
Valvoline, Pennzoil, RedLine, and a few others. Mobile One has always been rated highest in most all categories. We did dyno testing for Lubrication Sciences and Mobile Labs. All the synths are very good, Mobile One was at the top. I would not be afraid to use ANY brand name synthetic.
Jim Schings is offline   Reply With Quote
Old 08-11-2015, 08:35 AM   #18
I use it anyway !!!
He was completely wrong. However, the advantages are EXTREMELY small and hard to measure in typical tractor use. You probably don't use it in the winter, so excellent poor rates and great startup lubrication doesn't help much. You probably don't have a high lift cam with heavy valve springs so no help there. You probably stay well below 6500 RPM, so no help there. So about the ONLY gains you will get is a slight increase in fuel economy when the engine is cool. I would put some high performance parts on that thing to make it worth your while.
Old 08-12-2015, 06:37 AM   #19
I do use one of my tractors in the winter,,, unless my 48" snow blower decides not to work,,, which happen way to much !!!
Old 08-12-2015, 07:39 AM   #20
Great! Then let's put a high lift cam in there with an 1100 CFM carb, a high speed torque converter and spin it up to 6500 RPM. I think we will see some real gains with the Synthetic then...
