Old 07-22-2015, 02:38 PM   #1
Please help.. what type of oil
We are sitting here in a lube shop and the technical doesn't know what kind of oil to use in the motor of our fr3
colourful64 is offline   Reply With Quote
Old 07-22-2015, 02:53 PM   #2
Jim Schings's Avatar
5w20 (synth or blend or dino, your choice)
Jim Schings is offline   Reply With Quote
Old 07-22-2015, 02:54 PM   #3
fonzie's Avatar
It should say into your owners manual?
Fonzie
Old 07-22-2015, 02:58 PM   #4
5W20 Mobile One is about the best you can do. But the same grade in Valvoline etc. is plenty adequate.
Old 07-24-2015, 09:22 AM   #5
All owners manuals give you the oil brand or equal to the numbers describing the type oil to use.
Myrle is offline   Reply With Quote
Old 07-24-2015, 09:42 AM   #6
Wolverine 1945's Avatar
If it is a Ford,,, I believe they all come with 5w20 blend !!!
You may want to find another Lub Shop ???
Wolverine 1945 is offline   Reply With Quote
Old 07-24-2015, 09:52 AM   #7
I suggest you read up on motor oils and your engine requirements, for the next change. There are factors that come into play, based on frequency of use, etc. Also, your chassis mfg. will tell you what is recommended for your motor.
Old 07-24-2015, 10:10 AM   #8
I don't think we received an owners manual. And as for the lube shop we are travelling in the boonies there are no choices of lube shops you take what u get
Old 07-24-2015, 10:15 AM   #9
Motor Craft SAE 5W-20 or any oil that meets Ford Spec. WSS-M2C945-A lube shop can find a comparable oil. Ford likes you to use their oil more expensive than comparable oils.
Old 07-24-2015, 10:39 AM   #10
Ford dealership,,, would be a great choice !!!
