Old 05-23-2015, 06:37 AM   #1
Scootdawg's Avatar
Plex tubing and fittings starter kit
I am looking for advise in putting together a nice emergency kit incase I have a tube break or leak. Yes it happened to me last year while in my Sunseeker. I was able to plug the tube and continue with a nice weekend camping.
Now I have an 8289 5th wheel and I was looking at getting some plex tubing and connectors. What size tubing should I get? I also see that I should get some straight and 90 connectors and clamps.
Any and all advise is welcome!
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 05-23-2015, 06:47 AM   #2
Ford Idaho's Avatar
The Pex is generally 1/2 inch, check to be sure.
You will need the clamps unless you use the Sharkbite type fittings.
Yes a couple or three of the straight ones and a couple of 90's might be handy.
If you chose not to use the Sharks then the clamps and the crimp tool will be needed.
Old 05-23-2015, 06:54 AM   #3
The proper tools for PEX (Cutter/Crimp Tool/and Ring Cutter) can cost $$$! The area where a LEAK will develop will also (ALWAYS) be in a (HARD to get to area) where the Tools will NOT fit!! The PEX is (1/2") in size. For Emergency repairs (Sharkbite) or Barbed fitting with Hose clamps) might be a better choice? Youroo!!
Old 05-23-2015, 06:58 AM   #4
mcnabbwr's Avatar
Definitely check the size of tubing, my unit has both 1/2 & 3/8. I purchased a cinch clamp tool at HD which will handle 3/8-3/4 and a small selection of fittings.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 05-23-2015, 07:18 AM   #5
DDC
DDC's Avatar
I have found that it does not matter what or how much stuff you bring if you have a problem what you need to fix it is at home in the garage, just my personal experience.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-23-2015, 12:27 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I can ID with DDC,,,,,and if it's not there at home,,,,it'll take 2 or 3 trips to The Home Depot to get everything you need. And the five minute job will turn into a 4 hour job, right? Been there, done that!!
Grampa Jim is offline   Reply With Quote
Old 05-23-2015, 12:44 PM   #7
Stormrider151's Avatar
Yep, you guy's nailed it. I have the T shirt. Nothing is simple when your away from your tools.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-23-2015, 01:12 PM   #8
I gotta have one of those shirts!
Ultraboy is offline   Reply With Quote
Old 05-23-2015, 01:49 PM   #9
2007 WildCat 32QBBS
18CrewDually's Avatar
Give it time, you'll earn it!
18CrewDually is offline   Reply With Quote
Old 05-23-2015, 05:46 PM   #10
I you want to do something just buy some no 6 hose clamps and about 1 ft of 1/2" pex. The hose clamps will work until you get home. If you do buy pex fittings and sleeves buy the type of sleeve that crimps from the side. You can install them in any location and the crimp tool costs less than $30. Lowes and HD sell these.
palmetto rogue is offline   Reply With Quote
Old 05-27-2015, 07:40 PM   #11
pex plumbing
Pex is widely used in homes as well as rv's, so just go to a home depot or Lowes and get so pipe, and fittings. To make your job easier get the shark bite fittings as you do not need any tools to install them.
Hope this helps you out, did the same thing when I purchased my 5er.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 05-27-2015, 07:45 PM   #12
Ford Idaho's Avatar
I saw a ratchet type tube cutter at Walmart yesterday for about $12.
