Old 01-18-2015, 11:22 AM   #1
Pop up lift cables/rear guide channel
I was trying to lift the roof of my 2014 mac246d and something in the rear lift mechanism must have caught or snagged underneath. The bracket that secures the rear cable guides broke. Has anyone experienced this on a camper that has only been raised/lowered maybe 20 times? Does fixing the bracket require full disassembly of the lift system as it appears that this is the only solution.
griggsz71 is offline   Reply With Quote
Old 01-18-2015, 11:27 AM   #2
Platokidd's Avatar
Can you repair the bracket and try lifting again? Or did the bracket break because it was was binding and you still tried cranking it up?
I had to change a pulley on a bracket on one of my pups. Just had to take the tension off the cable first.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 01-18-2015, 01:17 PM   #3
Bracket broke when I tried cranking it. It had been sitting in the garage since thanksgiving so I thought my battery was dying without thinking further. I never would have imagined it being a problem with any of the lift system since it's essentially a brand new camper.
Old 01-18-2015, 02:03 PM   #4
Done with this
Can you get a pic of what broke? I had a similar problem once, and might be able to help if I had a pic.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
pop up
