Old 03-14-2011, 09:16 PM   #1
cmhbob's Avatar
Porch Light Covers
How do you get those amber covers off? I can't find a ridge or anything to pry on.
On a side note, I'm a little annoyed at having 3 blown lightbulbs in three weeks on the road....
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
cmhbob is offline   Reply With Quote
Old 03-14-2011, 09:26 PM   #2
miatared's Avatar
There is 1 notch at the top and 2 at the bottom. The front hitch light is the same - but white instead - have a look if you want.
You should be able to press it down with 2 fingers. squeeze the housing with your other hand (LH & RH side) and it pops out.
Or, very carefully, use a flat blade screwdriver to pry at the top and you will see the notch.
When you put in back, make sure it is tight - as I lost mine on the highway somewhere and had to buy a replacement...
Good luck
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
