Old 08-16-2016, 10:52 PM   #11
rattleNsmoke's Avatar
To answer your question crazyasian, I own a Champion 3100w unit with 120v\30A plug-in and it powers-up and runs my 15k BTU A\C just fine. It's great generator but you'll have to refuel every 5.5-6 hrs if running your A\C constantly.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 08-16-2016, 11:05 PM   #12
Taranwanderer's Avatar
+1 on the Champion 3100w unit you referenced (75531i)-- it runs my 13.5 AC without difficulty. This thread is a good read:
impressed with Champion 3100 inverter generator
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-16-2016, 11:20 PM   #13
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
I have two Champion 3500/4000 units and either will run my 15K BTU AC without any problem. The one that I keep with the unit at the storage yard is run every time I go there to clean up or do mods. It has over 1,100 hours on it and never missed a beat [$295 at Tractors Supply]. I have yet to find a need for an inverter generator.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 08-17-2016, 06:28 AM   #14
Originally Posted by Blackhat6mike View Post
I have two Champion 3500/4000 units...I have yet to find a need for an inverter generator.
They are safer for sensitive electronic equipment to be plugged into. It's easy to fry your cellphone, laptop, or iPad charging them with an open frame, non-inverter generator. Not to mention I wouldn't want to be next to you at a CG or race track while you're running your two open frame Champion units, unless I had earplugs.
Old 08-27-2016, 01:38 PM   #15
I installed one of these on my old pop-up and it made a world of difference. $8 and took 5 minutes to install.
lugoismad is offline   Reply With Quote
Old 08-28-2016, 09:22 AM   #16
yetavon's Avatar
I will also give a thumbs up to the Champion 3100I. We have 13.5K dometic A/C and our 3100I has no issue running it, along with the 2 fridges on electric.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017..... not enough
yetavon is offline   Reply With Quote
Old 08-28-2016, 09:42 AM   #17
NMWildcat's Avatar
Honda and Yamaha inverter generators are the top of the line. Start there and if you can't afford those then look at the knock offs like champions and boliy.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-30-2016, 06:19 PM   #18
I wouldn't call Champion a "knock-off." It's not a clone of Honda or Yamaha, it's a completely independently engineered similar product that happens to cost a third less than H or Y.
Now Boliy looks like a rebadged Yamaha to me, but...
Old 08-30-2016, 06:29 PM   #19
W5CI's Avatar
I had the Champion 3000/3500 It would not run a 13.5 AC, when the AC cycled the Gen would shut down due to overload. I got rid of it and got a Honda 3000 Handi, it will run the same 13.5 AC only if I leave the ECO mode off. With the ECO mode on when AC cyales it will trip out also. The Honda 3000 Handi will only run 4 hours with the ECO mode off.
2004 Cedar Creek 30RLBS RV FlexArmor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29
2016 Days Camping 50
W5CI is offline   Reply With Quote
Old 09-01-2016, 07:27 PM   #20
King of the Road
X2. I also have a 2k Energizer CONVERTER generator. That cost twice what the champion did, but need the converter. My 5ver has an inverter, don't need the cost of inverter genny.
Sent from my LG-H830 using Tapatalk
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
Dano1955 is offline   Reply With Quote
3500, 500, generator, georgetown
