Old 08-15-2016, 01:13 PM   #1
Portable Generator to run 13,500 Btu A/C unit on 2008 Georgetown 350
trying to find a portable generator/inverter that will be able to run one rooftop A/C. currently have a Guardian Generac QP65 (6500 watts) 120V/240V single phase 60 hertz. found few generators that have a 30 amp output but is only 120V. my ONE & ONLY question is do i need a 120V/240V generator to be able to run a 13,500 Btu rooftop A/C or is a 120V generator with a 30 amp output sufficient? for example will a "Champion Power Equipment 75531i" be good enough to run one A/C unit? i only need the generator on when i'm driving in the hot summer heat and one A/C will be sufficient. MH does not have an auto transfer switch.
Back story:
current generator has about 3000 hours on it and is backfiring like crazy (idle & under load). i've done the following and the problem still exist:
- changed both plugs (it'll run nicely for a few hours then problem starts again)
- changed air filter (nothing)
- changed fuel filter (nothing)
- cleaned combustion chamber with Mopar and water (it'll run nicely for a few hours then problem starts again)
- changed carburetor (new - ran nicely for a few hours then problem starts again)
- upgraded to 92 octane
- added Stabil, Seafoam, etc. (nothing)
- unplugged breather hose from intake (nothing)
- compression test (both cylinder good at approx. 122 psi)
one thing worth mentioning is when i pulled both plugs one of them seems to be really dirty. once i clean the heads or install new plugs it seems to run fine until the plugs get dirty again. there's something causing a bad combustion in that one chamber and i can't figure it out. I am out of ideas. the only thing left that i can think of is a faulty stator (not easy to get to).
crazyasian is offline   Reply With Quote
Old 08-15-2016, 01:26 PM   #2
JustB_Rad's Avatar
If it has a 30A outlet on it, it will run a 13,500 unit, obviously provided its big enough to power it. You may need to put a hard start capacitor on your AC just to not overload your Genny during startup though.
A running 13,500 unit draws around 12-1300 Watts while running.....as stated, startup is where it draws more, but that Genny should still do a fine job.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017)16 Night Booked in 4 Trips - 6 in 2 more Trips Planned
JustB_Rad is offline   Reply With Quote
Old 08-15-2016, 01:30 PM   #3
Thanks, i heard about that but haven't done much research on it. i take it just find the same spec capacitor with hard start? to save me some time, do you have something you can refer?
Old 08-15-2016, 01:34 PM   #4
Flybob's Avatar
Every AC appliance in the coach should be 120VAC. You can run one AC on a 30A source, but you will need to be careful not to run other high draw items ( ie microwave) at the same time.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-15-2016, 01:34 PM   #5
JustB_Rad's Avatar
Honestly I don't have the info...I've briefly looked into adding it, but don't do any dry camping so dropped that quest for information. I'm sure somebody around here who's done it can chime in. From what I've read on here it's pretty simple to do.
Old 08-15-2016, 01:36 PM   #6
Georgia Frog Rally 2017
aceinspp's Avatar
If your looking to invest in new Gen go here Boliy Generator and make the comparisons of Champion and Boliy. I have the Boliy and runs my 15000btu ac. just fine. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 15
Days booked so far in 2017 37
Old 08-15-2016, 01:40 PM   #7
bob213's Avatar
Suppco Spp6E or SPP6 depending on who you talk to. I have used both and they both work. Spp6 is what rep at Supco told me to use. The guys "in the field" who frequent this forum say to use the SPP6E.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 08-15-2016, 04:30 PM   #8
very interested but not a lot of new information on these. reviews are of older models (2012 and older). wondering if it has gotten better.
Old 08-15-2016, 07:02 PM   #9
My Boliy ran my airconditioning just fine for the past 4 1/2 years until last month. My stepper motor that controls the motor is too slow to adjust to increased low causing engine to die. $12.99 plus shipping and 20 minutes of labor and I'm back in business. I can't complain since that has been the only problem with my Boliy over the years.
Skyliner is offline   Reply With Quote
Old 08-16-2016, 09:44 PM   #10
Marcus
On your generac check your Ignition system . They are heat sensitive and can work cold and arc out when hot. Dead spark will cause fuel to ignite late outside the cylinder. Coils use to go when hot. The new solid state can have the same issues. Check the resistance of your ignition system when cold and hot.
Purchased a toy hauler to carry this in bad weather:
http://i1355.photobucket.com/albums/...psumn26tdr.jpg
MarcusWS is offline   Reply With Quote
3500, 500, generator, georgetown
