09-11-2011, 11:29 AM
Power cord problem?
We have camped alot this summer in oklahoma where it has been hot! As we were packing up from our last trip we noticed one of the power cord prongs were burned and the plastc around it slightly melted. We had no loss of power during our trip. ? Is do we need a new cord (30 amp) and what happened? Our trailer is 6 mos. old.
Pam
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
09-11-2011, 11:37 AM
I'm guessing maybe a "loose fit"; maybe a small gap and a little arcing. Have you been using the ring around the plug (at the trailer) to tighten the connection?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
09-11-2011, 11:59 AM
It was the end plugged into the park power,sorry should have said. We are ready to go but worried about cord.
Pam & Don
2011 Rockwood 2304s
09-11-2011, 12:28 PM
I think there you can replace the end plug so it might be worth it to ask someone at the local RV store or even your dealership service department to find out the answer.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
09-11-2011, 12:34 PM
Phat Phrog Phlunky
you should be fine. Make sure you get a good tight connection on the park power side. If need be, slightly bent the prongs on the plug to make sure you are getting good contact.
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
09-11-2011, 02:03 PM
Burned blades should be lightly sanded bright. Use a 600 grit wet and dry paper available at any car store's body repair section.
Burned tips are high resistance connections and get HOT. They use amps that you will need in your camper; not being converted to heat.
The arcing will also cause burn spots in the campground's socket and you will damage every outlet you plug into. Chances are good your plug was ruined by a bad socket caused by a shore cord just like yours being plugged into a "good socket" that was ruined. Help a friend you might never meet and get that plug replaced or at least cleaned up.
NEVER plug in your shore cord plug without turning off the socket's breaker. Plug in; then turn on the breaker. You will arc your plug every time you make or break a connection if you don't.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
09-11-2011, 02:04 PM
Make sure prongs are clean and dry.. Dirt can cause all kinds of problems.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
09-11-2011, 02:15 PM
like stated above if the prongs are bad you can replace the cable end and call it good for that piece of mind
Connector side = Wire Side
Gold = Black
Silver = White
Green = Green
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
09-11-2011, 02:22 PM
09-11-2011, 02:58 PM
You guys are great! Thanks so much for the info. We have ordered new plug and will be more careful when we plugin. We are newbies and learning and this is the place to come for great info.
Thanks again
Pam
09-11-2011, 03:08 PM
Our cord was damaged like yours last summer by a loose fit at a run down campground. I brought it to the dealer and he said not to worry about it. A bit over a year later it is still working fine with no further damage.
09-11-2011, 03:54 PM
Thanks again
Pam
Pam,
Needs to be said... Don't forget to turn OFF the breaker before you unplug as well.
