Forest River Forums
Sunline User Photos
Old 09-11-2011, 11:29 AM   #1
iluvlcy's Avatar
Power cord problem?
We have camped alot this summer in oklahoma where it has been hot! As we were packing up from our last trip we noticed one of the power cord prongs were burned and the plastc around it slightly melted. We had no loss of power during our trip. ? Is do we need a new cord (30 amp) and what happened? Our trailer is 6 mos. old.
Pam
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
31 days camped 2011
25 days camped 2012
iluvlcy is offline   Reply With Quote
Old 09-11-2011, 11:37 AM   #2
Moderator
acadianbob's Avatar
I'm guessing maybe a "loose fit"; maybe a small gap and a little arcing. Have you been using the ring around the plug (at the trailer) to tighten the connection?
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
Old 09-11-2011, 11:59 AM   #3
iluvlcy's Avatar
It was the end plugged into the park power,sorry should have said. We are ready to go but worried about cord.
Pam & Don
2011 Rockwood 2304s
31 days camped 2011
25 days camped 2012
Old 09-11-2011, 12:28 PM   #4
Moderator
Terier's Avatar
I think there you can replace the end plug so it might be worth it to ask someone at the local RV store or even your dealership service department to find out the answer.
16 Trips / 43 Nights / 1204 Miles
Old 09-11-2011, 12:34 PM   #5
A Little Off
essness's Avatar
you should be fine. Make sure you get a good tight connection on the park power side. If need be, slightly bent the prongs on the plug to make sure you are getting good contact.
Scot
2012 Grey Wolf 21RR
2009 Ford Expedition EB
Days camped in 2011 = 24 Next year we try harder.
Days camped in 2012 = 0 (weather needs to break soon!)
igkra.com
essness is offline   Reply With Quote
Old 09-11-2011, 02:03 PM   #6
Lou Amadio
herk7769's Avatar
Burned blades should be lightly sanded bright. Use a 600 grit wet and dry paper available at any car store's body repair section.
Burned tips are high resistance connections and get HOT. They use amps that you will need in your camper; not being converted to heat.
The arcing will also cause burn spots in the campground's socket and you will damage every outlet you plug into. Chances are good your plug was ruined by a bad socket caused by a shore cord just like yours being plugged into a "good socket" that was ruined. Help a friend you might never meet and get that plug replaced or at least cleaned up.
NEVER plug in your shore cord plug without turning off the socket's breaker. Plug in; then turn on the breaker. You will arc your plug every time you make or break a connection if you don't.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 09-11-2011, 02:04 PM   #7
rbarrieau's Avatar
Make sure prongs are clean and dry.. Dirt can cause all kinds of problems.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 09-11-2011, 02:15 PM   #8
sherdep's Avatar
like stated above if the prongs are bad you can replace the cable end and call it good for that piece of mind
Connector side = Wire Side
Gold = Black
Silver = White
Green = Green
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 09-11-2011, 02:22 PM   #9
Lou Amadio
herk7769's Avatar
Camco Mfg Inc - Power Grip Replacement Plug - 30A - Electrical Adapters - Camping World
16 bucks plus shipping.
Old 09-11-2011, 02:58 PM   #10
iluvlcy's Avatar
You guys are great! Thanks so much for the info. We have ordered new plug and will be more careful when we plugin. We are newbies and learning and this is the place to come for great info.
Thanks again
Pam
» Online Users: 674
148 members and 526 guests
11XLITE28BH, 64c10, alphadog99, alpinemike, BeagleIL, Bigmatt, bikendan, blaisrv, BlakeB, bob34787, boubou, brookside, Buffalohunter, bwbarnes, Cafjackracing, camper1953, camping4us, Capsfloyd, carsonizik3, Cascade Bob, cdbus, ChrisZazzara, Cowracer, creed, CRZ, Csbower, cstover, cyclepuck, DAISY BOYKIN, dapersico, davidjb, depo, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, dunnnc, EL99jl, emljr, Emptypockets, extremebike, Falcon35, feerobk, Fire Instructor, Flashg_123, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, grhodes50, growe, Hamblen, HemiCab, Hilgy, hotrodj125, itat, itech, Itsthetwoofus, Janet H, jar3316, jjm901, jkinger, jmswms, jobren4, jrb988, Juan.Cortes, ken0042, Kevin-and-Julie, KKapa, KoolAide, lbhird, ldmcmahan, ldprice47, LFugate, lochsa, Loopyhamil, LuckyMcBRIDE, mbfree66, mbrwr, mhartzel, Michigan, Mickey1, mike2tall, mike54, Mrgary, NanaKaren, NINA, Nursx2, papap, pgordemer, pg_rider, Piston, Playtime III, pmsherman, Poppy Bill, pryner, punkaccountant, pwadini, RattVader, rbrandon, redfox217, Redheaded blue tick, Retired63, rgmiller32, rick51, rickthelen, RJHuser, rob2112, rotorhead1250, SabreSam, Sahgie, Sailfish Bret, scroses40, SDENN4281, shane1234, shavard, sideout1961, SimchaSabre, skullskidr, snjparham, Snowsail, T.Kott, TacBear, Tee, Test Account, texashatter, Titleguy, tmmar, trailraider, travyp, Triguy, True Believer, tshayn, tsmcmillen, UPGRADER, vlite2011, wagon52, washdweller, wayne anthony, wellcoman, whj77372, wnytaxman, y01lxb
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
