Old 04-25-2011, 02:53 PM   #1
power drain?
Have a 2012 windjammer 3008w, The battery seems to discharge in about a day. I cannot find anything running inside any ideas?
Dave & Gloria
2012 Windjammer 3008W
dgh7 is offline   Reply With Quote
Old 04-25-2011, 03:48 PM   #2
Dave & Gloria
Old 04-25-2011, 03:57 PM   #3
bikendan's Avatar
all RV's have parasitic power drains and what happened to you, isn't unusual for new owners.
things like the CO2 or propane alarms are hard-wired and will draw battery power, along with the clock on the stereo.
most of us install a battery disconnect switch or you can simply take the cable off.
do a search on battery disconnect switch and you'll find hundreds of posts on the subject.
Old 04-25-2011, 03:57 PM   #4
Did you check the gas detector? I had a problem with my old Rockwood. Also the radio even though its off drains the battery but it takes longer than a day.
Charlie
Papa Roo is offline   Reply With Quote
Old 04-25-2011, 04:35 PM   #5
First thing to do is charge the battery, and verify full charge with a meter, around 12.8 volts or so. Then disconnect the ground cable and go away for 2 days. Come back and check the battery voltage, should be over 12 volts. If not, it's battery time. If it is, wait till almost dark to hook it up. When you connect the ground wire, previously removed, pay attention to how big a spark you get. If it is large, you have a problem. If it is small or none, connect and tighten. Now go in and pull all the 12 volt fuses, making note of what came from where. Now wait another day and check the battery. If it is drained, then it is something hardwired. Slide, gas detector, other stuff.
There is a faster way, with a a voltmeter. Obtain a 1 ohm, 5 watt resistor. (radio shack maybe). Connect one end of the resistor to the negative lead. Connect the other end to the negative post. Now measure across the resistor with your voltmeter, negative lead to negative post on the battery. Use the 2 volt scale. I won't get in to the math, but if you read 1.2 volts. for instance, that means you r are pulling 1.2 amps out of your battery. (the math works by having a 1 ohm resistor). You can start pulling circuits and checking fuses until the voltage reading is very low, .1 volts or less.
Good luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-25-2011, 04:40 PM   #6
thanks
Dave & Gloria
