Old 09-08-2011, 11:51 AM   #11
Herk7769's Avatar
Originally Posted by Triathletedave View Post
I just took delivery of my lightweight Surveyor SV-294, and it seems to blow the 15A fuse every time I retract the stabilizer jacks. Has anyone else experienced this? Should the dealer be able to fix it? So far the only thing they have offered is to replace the fuse. Not much help if it just blows again the next time I use it!
I read this as the power stabilizers. There is a mod to add an auto-resetting fuse near the motor switch. Some units did not get this mandatory piece of equipment.
Name:	Hidden circuit protection rear stabilizers.jpg
File Type: pdf 0175-electric-landing-gear-circuits.pdf (36.6 KB, 133 views)
HAM CALLSIGN - KC3FFW
Old 09-10-2011, 05:08 PM   #12
I second Kpinto. I have 2010 flag 5th wheel (28 rk). Woull blow fuse every time I would retrack. Dealer states this "appeared" a couple of years ago with a change in their supplier. Marked my legs and installed a fuse that you can reset when tripped.
tom.keith is offline   Reply With Quote
Old 09-10-2011, 08:45 PM   #13
Bill_C's Avatar
Originally Posted by Kpinto View Post
Are you retracting them until they stop? I had a 5th wheel and if I ran the front landing gear in to far it would blow a fuse. I simple put a mark on the extended legs and only retracted them to that point. Could be why it only blows when you retract them?
x2
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 09-12-2011, 05:02 PM   #14
Danimal's Avatar
my 8281ss blows the fuses in the front jacks with out bottoming, it also blows the small slide fuse and the rear jacks blows fuses also, and it always works fine at the dealer, ( something is happing when i transport it from one place to another )
it at the dealer AGAIN for this problem ( i hope they can fix it )
2005 Dodge Ram
2011 Rockwood 8281SS
Danimal is offline   Reply With Quote
Old 09-12-2011, 06:03 PM   #15
Old car's Avatar
The fuse blew the first time I retracted the stabilizers. I ran them up to high and "bumped" the motor. Replaced the fuse and stop just short of bumping. Only had to replace the one time.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 09-12-2011, 07:01 PM   #16
Herk7769's Avatar
This is a known issue and an "instruction" was sent out by Lippert.
While they won't pay for the repair (I think) they have a "work around" paper out to the dealers.
File Type: pdf 0175-electric-landing-gear-circuits.pdf (36.6 KB, 320 views)
Old 09-19-2011, 01:43 PM   #17
Triathletedave's Avatar
The dealer has checked and tested the electric motors on my unit. Turns out they upgraded to 30 amp motors on the surveyor units, but they didn't upgrade the in-line fuses to match the new motor specs.
The dealer switched the fuses and assured me that this will fully resolve the issue. I'll be marking a 'stopping point' on the jacks just in case, but I hope this is the end of the problem.
Triathletedave is offline   Reply With Quote
Old 09-19-2011, 06:48 PM   #18
fivecodys's Avatar
I had the same thing happen to me.
I used a sharpie to make the mark.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 09-19-2011, 06:59 PM   #19
Herk7769's Avatar
Seriously folks. Look at the Lippert fix for this problem.
I went through 6 30 amp fuses on my first weekend trip. Put the auto-resetting fuse in and have never had a problem again. Simple, and I do mean simple, fix. A buck 69 and done with it.
http://intecons.in/clientProjects/Op...B2-PL_RevB.pdf
Old 09-19-2011, 08:01 PM   #20
Herk's approach looks like the "correct" fix. I was blowing 30 amp fuses when I ran jacks all the way up. Motor was only drawing 23 amps during the return. My fix (a 25 amp fuse that you can reset by pushing on the top) has worked so far. Only understand electric stuff enough to be dangerous, but this seems to accomplish the same thing.
jacks, power, fuse
